29th Nov 2019, 1:25 am | #1 |
Laney IRT15H
I am working on a Laney guitar amp. I just wish to post some pics regarding removal of the circuit board.
The two pictures are pretty self explanatory, so to explain why I have posted this is as follows: The pilot lamps ( two of them ) are soldered into the BOTTOM of the PCB. The (led) lamp itself is hot glued to the chassis. Which is removed first? The 16 way header is GLUED into the socket!!! at BOTH ends. I guess it makes for a "solid" (sic) connection, but how is it removed?? I have seen some dodgy bodgy "fixes" before but I had to share this one. Note also the large amount of SMD components!! Joe |
30th Nov 2019, 10:26 am | #2 |
Re: Laney IRT15H
Hi Joe,
It looks like hot melt glue. If so, I find brushing the bond with isopropyl alcohol works. It doesn't totally dissolve the glue, but softens it, allowing you to peel it off. It usually takes a couple of applications.
Martin BVWS member GQRP Club |
30th Nov 2019, 10:40 am | #3 |
Re: Laney IRT15H
To my eyes that looks like some quite-sensible and cheap "roadie-proofing"!
Not exactly tour-grade, but good-enough. Amps and cabs have a hard life on the road (beer-cooled amplifiers were a regular thing). |
30th Nov 2019, 5:22 pm | #4 |
Re: Laney IRT15H
Hot melt glue cooled down tends to snap off, pop it in the freezer (if it fits) or outdoors overnight.
30th Nov 2019, 6:28 pm | #5 |
Re: Laney IRT15H
I soften hot melt glue with a heat gun on a low setting, allowing stuff to just pull out.
Kevin |
