26th Nov 2019, 2:03 pm | #1 |
Any ideas what this plug used for?
Hi guys
anyone got any ideas what this connector would be used for. 3 pin female plug with twist on connector. Plug 15mm diameter overall 25mm diameter. Cheers |
26th Nov 2019, 2:07 pm | #2 |
Re: Any ideas what this plug used for
Avo CT378 signal generator, Avo CT160 valve tester, Murphy B40 receiver amongst others ?
Lawrence. Last edited by ms660; 26th Nov 2019 at 2:20 pm. Reason: addition |
26th Nov 2019, 2:43 pm | #3 |
It looks the same as the power connector on my Solartron SRS153S variable PSU.
Martin BVWS member GQRP Club |
26th Nov 2019, 3:27 pm | #4 |
Thanks guys I thought it might be for test equipment got it with various leads but not something I'll use.
Could post as freebie someone might need it. Cheers Chris |
26th Nov 2019, 3:31 pm | #5 |
The same plug can be assembled in different ways so that the locations keys are oriented differently with respect to the contacts.
It is also used on the Racal RA17 and associated kit (like the SSB and low frequency adaptors. Craig |
26th Nov 2019, 3:34 pm | #6 |
It's a Plessey plug, fits military issue instruments from Hartley, Solartron, Met Vic etc,
Neil
26th Nov 2019, 3:37 pm | #7 |
That is a valuable connector.
They fit a wide range of vintage test gear and some people will pay up to £25 for them. I think the B40 comms receiver uses the 2 pin version. I have got enough for my gear that uses them. |
26th Nov 2019, 3:57 pm | #8 |
Now made by Weald and sold through FC Lane. In a former job we used them on radar sets and in their multi-pole version, on reflected infra-red cameras that checked the moisture content of clay in the pottery industry.
Kevin |
26th Nov 2019, 4:11 pm | #9 |
Oh okay many thanks for that guys I did not realise it was worth a few quid I'll post it up for sale think 15 quid must be fair price plus postage. It still has an original EDISWAN mains plug that's interesting as its incredibly heavy for a plug plus it has 4 screws not seen that before and something in middle. Heres a Pic know it's just a plug but not seen one like it before.
26th Nov 2019, 4:12 pm | #10 |
The centre black insert can be fixed in different keyed locations to customise exactly what it mates with. The Ra17 and ct160 ones I have seen use different configurations. Easy enough to change.....once you can get it apart.
No doubt, as well as the two I mentioned (and the other people), there are numerous other items that it will fit. Rob Part of my info crossed with Craig!
26th Nov 2019, 5:28 pm | #11 |
Back in the 70s my partnts' old Morphy Richards "Noiseless" hairdryer had one of those Ediswan plugs. When as a student I 'inherited' said hairdryer I took the Ediswan plug off and replaced it by a brown MK 15-amp BS546 because the halls-of-residence were all still round-pin.
26th Nov 2019, 6:24 pm | #12 |
Blimey that's going back still having round plug sockets funny enough other way round for me I have some round pin plugs but can't use them now ha ha.
Mind you there definitely a heavy duty plug can't believe the weight of it. |
26th Nov 2019, 8:20 pm | #13 |
Continued here: https://www.vintage-radio.net/forum/...86#post1194786
