27th Nov 2019, 9:32 am | #21 | |
Re: Back-EMF from series and parallel inductors?
But, unfortunately, it's become established. And ultimately, it's what people understand by a word or phrase which matters, whether or not the words of the phrase are appropriate or not. |
27th Nov 2019, 12:03 pm | #22 | |
No Longer a Member
In the end of course it may well be just semantics, because V = - L(di)/dt is never violated. It got me to thinking whether there could be a better way to name the flyback or impulse power supply. If a pressure gradient is applied to an elastic fluid filled tube, initially there is a reactive pressure from the column of fluid, which like any mass , resists a change in motion. So you get a back pressure from it (like back emf). After a while the fluid current reaches a stable flow rate and the reactive pressure disappears, just as back emf does. The equivalent of disconnecting the inductor, is cutting off the flow, say with a valve that isolates the pressure source abruptly from the fluid column. When that happens the motion (kinetic energy of the fluid) generates a reverse or negative pressure. Like pulling on a mass moving away from you. Due to the system compliance (capacitance) it sets up a series of oscillations in the tubing. Much like the inductor when it had a current & magnetic field established, and you shut it off abruptly. In plumbing of course this is called a "Water Hammer" effect. So maybe these impulse power supplies could be called an "Electron Hammer" And you harvest the first half cycle for your high voltage. |
27th Nov 2019, 5:35 pm | #23 | |
emf
Most TVs have had booster/efficiency diodes for as long as I can remember (PY81, PY800, PY88 and PY500). http://www.r-type.org/pdfs/py800.pdf Numerous boost converter ICs are available: https://uk.rs-online.com/web/c/semic...st-converters/ David |
27th Nov 2019, 6:59 pm | #24 | |
Boost converter always gives an output voltage higher than input (and is inherently NOT short-circuit proof). Flyback can do everything. They do both rely on the (ahem...) back-EMF of the inductor when the switch is turned off. |
28th Nov 2019, 1:11 am | #25 |
To my understanding, back emf is stated in Lenz's law. Lenz's law states that the current induced in a circuit due to a change or a motion in a magnetic field is so directed as to oppose the change in flux and to exert a mechanical force opposing the motion.
As I and a lot of blokes who worked on rail circuits with track circuits, the voltage generated can be nasty. For a simple inductor, the voltage is ( in simplest form) = L x (di/dt). For a transformer ( before someone comes in saying it's different- it is) , thre's also the effects on the secondary etc. |
30th Nov 2019, 7:18 pm | #26 |
No Longer a Member
Here is something that is very helpful in designing a flyback converter.
If the feedback which generates and sustains the oscillations originates from the transformer itself, it solves the problem of the inefficiencies that occur when the rate of change of current with time becomes non-linear and tapers off. Since the induced voltage is proportional to the rate of change of current, the feedback simply falls away as the rate of rise of current becomes non linear, and then as that happens the feedback voltage drops suddenly and abruptly cuts off the transistor. So the circuit automatically adjusts itself to suit the inductance properties of the transformer and you don't have to worry about the transistor being turned on for too long by the driver circuit, plus it gets rid of a driver transistor. And on top of that, the circuit is intrinsically short circuit proof. Flyback supplies are used in aircraft exciters, to get the voltage up enough to strike a GDT. Typical circuit attached. |
