10th Nov 2019, 3:40 pm | #41 |
Re: Soldering Iron For PCB's
Well said Stuart.
I would go for an Antex every time. I did buy a cheap Lidl soldering station a few years ago as an experiment, but found it had very poor temperature control and the bit wore quickly. I soon went back to my 30 year old Radiospares badged 18W Antex. (See #23.) I would certainly use Weller/Metcal pro gear if somebody gave it to me, and don't doubt that it would work very well. I'm not going to spend my own money on it though. |
10th Nov 2019, 3:57 pm | #42 |
Brian (the OP) seems to have gone quiet; perhaps we have overwhelmed him with different opinions? While he did say that he didn't want spend very much, perhaps if he could turn that in to a number, it would focus the discussion.
If his budget is really tight, it could be that he actually has few options other than a simple Antex, and that would not be anything really terrible...really. Many (most?) of us cut our teeth on Henley Solons, which I suppose were the Antex of their day! B
10th Nov 2019, 4:15 pm | #43 |
Well lots of people have recommended Antex, even the likes of Metcal/Oki users such as myself.
10th Nov 2019, 4:37 pm | #44 | |
Still got one in the cupboard for use if all else fails.
Chris |
10th Nov 2019, 4:41 pm | #45 |
I have in the past made a copper attachment for a Henley Solon iron in order to desolder 16 pin conventional ICs. Have also used a Variac to control the maximum temperature of Solon and Antex irons. I mention these things simply to illustrate the flexibility of basic but robust soldering irons. Robustness is important to me because it always takes time to adapt your technique to suit a new soldering iron so an iron that is well made and that will last is well worth acquiring.
Alan Last edited by ajgriff; 10th Nov 2019 at 5:06 pm. Reason: Corrections |
10th Nov 2019, 5:29 pm | #46 |
For anyone considering buying an Antex XS25 it's well worth spending an extra pound or two on the silicone cable option. The standard PVC cable is rather stiff and as a result tends to get in the way as well hampering manipulation of the iron. In addition to being heat resistant the silicone cable is much more flexible.
Alan |
10th Nov 2019, 5:57 pm | #47 |
If you fit a switchable 1N4007 in the mains lead you have an instant high/low switch. You can also use a lighting dimmer to reduce the heat.
10th Nov 2019, 6:30 pm | #48 |
There's a weller temp controlled iron in the for sale section right now at an affordable price (there were two, but one already has a taker)
10th Nov 2019, 6:40 pm | #49 |
Snapped up pretty smartly by the looks of it.
Alan |
11th Nov 2019, 8:20 am | #50 | |
11th Nov 2019, 8:57 am | #51 | |
Although they feel as if there is a transformer in the base, it is just a weight glued in to stop the base falling over when you remove & replace the iron. I bought a similar one to tide me over when my Weller WTCP croaked. The "cheapie's"performance was abysmal. Being a "grey beard", I knew a few "tricks", & was able to make reasonable joints on new work, but for rework-----aaaarrrrgggghhh! |
11th Nov 2019, 9:30 am | #52 |
Well, I guess you can control the temperature. But it's not kept constant during soldering.
11th Nov 2019, 9:47 am | #53 |
I tried a Lidl one a few years ago, it wasn't very good and died quite quickly probably because it was 220v not 240. It also put out an awful lot of HF hash.
11th Nov 2019, 10:57 am | #54 |
I have recently been given an RS soldering station. RS no longer stock these items. On the detachable tip it says No 544-601 made in USA, are these station temperature controlled and should I require a replacement tip does any one know of a supplier. The tip does get hot. Finally how are they rated.
11th Nov 2019, 9:54 pm | #55 |
I'm one of those people who does electronics for a living, and am lucky enough to have a Metcal MX500 and a good selection of bits. It makes light work of everything from 0.5mm pitch surface-mount components to 50mm2 (300 amp rated) cables. It does have the auto-off function, which is fortunate because professional electronics design involves surprisingly little soldering!
However, that's a high-end piece of kit which is way beyond most people's needs and budget. For home use, I'd recommend the Antex mains-powered irons every time. Their combination of light weight, high temperature, sheer effectiveness of getting heat in to the joint, and easy parts availability is unbeatable. My top tip: make sure you get the proper Antex stand, which has the bit in contact with the metal 'spring' of the stand. It stops the iron overheating when it's resting, and makes the bits and elements last much longer. All the other mains-powered irons I've ever tried, from no-name far eastern cheapies to Weller ones, haven't been as good as the trusty yellow Antex XS25 which lives in my 'portable' tool case. I grew up with an Antex CS, which eventually fell to pieces after innumerable replacement bits and several replacement elements. I also have an Antex temperature-controlled soldering station, a 690SD, at home which conveniently takes the same bits as the XS25. It's not in the same league as the Metcal but it's still very effective, reliable, and routinely gets used for work on surface-mount PCBs as well. Chris
11th Nov 2019, 10:50 pm | #56 | |
12th Nov 2019, 8:45 am | #57 | |
Hugh |
12th Nov 2019, 12:46 pm | #58 | |
I started with a GEC Henley Solon, 15W, but upgraded to a 25W.
Once I started using a temperature controlled iron, I never looked back! Bought myself an Oryx for home, but it wasn't as good as Weller. Quote:
Weller TCP irons are really good, I still use one at work. Bits last ages. Usually use a No 7 temperature bit, but occasionally a No 8 for stripping solderable enamelled wire. Lots of different shapes too. I also have a 100W Weller iron - can't remember the type number - again using their Magnastat system, which is used occasionally when the extra heat delivery is needed. And I do have a (salvaged) Metcal, it's super. But I keep it switched off except when in use. So for the OP, I'd recommend a secondhand Weller TCP. I've never used a massive copper bit, externally heated iron though... |
12th Nov 2019, 1:06 pm | #59 |
12th Nov 2019, 1:22 pm | #60 |
Nor would you want to!!
Mine would never sit on top of the blowlamp properly. |
