31st Oct 2019, 12:51 pm | #41 |
Re: What's your winter project?
For the moment, dropping temperatures are concentrating my mind on partitioning the loft. Attempting to heat the northern hemisphere is proving to be impossible.
31st Oct 2019, 7:08 pm | #42 |
As we continue to see the warning signs of Global Warming I'm wondering if I should go about ordering my row of vines to plant up here in Glasgow?
Too soon ...? Meantime, I've got to get that Kolster-Brandes MR10 finished and move on to my ToDo pile, in no particular order: - Roberts R303 Philco A535W Dansette Conquest HMV 101 portable gramophone HMV 102 portable gramophone Acoustic Research 28S speakers to re-foam, re-wire and re-cap Heathkit Signal Generator Velleman k7000 signal injector/tracer - stopped working? Raspberry Pi and Volumio music player Bush TR82/B Various other network points to make live; speaker cables to extend and fix; new mains leads to construct. And for the audiophiles (audiofools!) among us I'm waiting for Linn Products to release Space Optimisation Version 2 for Exakt ...!
BVWS Member |
31st Oct 2019, 7:30 pm | #43 |
Get the vines!Though it was -5C when I was up Killin last week.
31st Oct 2019, 9:21 pm | #44 |
My to do pile just got 2 more jobs added! A Pure Evoke flow DAB radio with a duff OLED display, you can still see the display in a dark room, sound quality is good! And the other is a Roberts RD50 DAB radio, which needs re-covering since the original black leatherette stuff fell apart and turned sticky, a bit like that horrible rubber paint does. I’ve got some dark coloured denim to cover it!
Regards Lloyd |
31st Oct 2019, 11:27 pm | #45 |
One right now - a super-regen FM front-end, based around an ECC81 (RF amp + SR detector). I am working on a design here to cut my teeth on before branching out myself (aim to use TV VHF tuner valves).
31st Oct 2019, 11:50 pm | #46 |
I hope to return to restoring my Garrard ‘high fidelity’ 78 head from the RC60, which I first mentioned here:
https://www.vintage-radio.net/forum/...54#post1136154 , Sadly, it found its way onto the ‘too difficult’ shelf because of its stage of deterioration. But I have ambitions to rebuild it in order to find out just how good was this 1940s milestone in audio quality. Martin
BVWS Member |
7th Nov 2019, 3:39 pm | #47 |
Currently I am working on a CVC8 on loan from Bobby Ball.
So far I've repaired the cracks in the colour mod board, repaired the control panel, cleaned up the switches and of course had to take the power switch apart to clean it (what a nightmare). Just a matter of recapping now then putting back together. Another is to get a converter and have the Philips 1200u running with Amazon Firestick (has anyone tried this?) and of course sort out the Head Servo issue on a Sanyo VTC-5600p. Paul |
8th Nov 2019, 2:38 am | #48 |
Where do I begin
Having just had to clear my late father's house of all my "conveniently forgotten about" effects and half finished projects, I have an influx of all things electronic and lots of ready re-polished cabinets waiting to be re-united with their not yet restored works. I need to retire...
Robert |
24th Nov 2019, 3:05 pm | #49 |
Another shed to build, windows to fix/paint and general house maintenance to do. On the electronics side a Heathkit OC 11 scope to recap, a faulty Heathkit VTM to sort, several 'finds' to restore, some Avos (Mostly 8 mk 5 and 6) to troubleshoot. OK not winter here in NZ I know but comfortable for that sort of thing.
24th Nov 2019, 5:58 pm | #50 |
Let me say,when you retire you will wonder then how the heck you found time to work!
24th Nov 2019, 7:53 pm | #51 |
Hi!
I've got a Mullard O.A.B. 7600/4 to restore, a Walder & Goltermann SPM30 Level Meter (to collect from Hampshire & waiting to hear from Telford Electronics re service manuals!), a Wharfedale amplifier my friend bought from the house clearance shop, a Rigonda Bolshoi Stereogram, a pile off impulse–buy surround sound/home theatre receivers with assorted faults, etc., and that's before I begin on the twenty Oscilloscopes and innumerable smaller pieces of gear I've collected over the years! Chris Williams
28th Nov 2019, 7:48 am | #52 |
I have several Tektronix 500 series scopes that need restoring, a few amplifiers to build, a mixing desk to restore but like Sisyphus the main task is trying to keep my workshop tidy. I have a mad tidying session, clean, clutter free benches, a floor you can walk on without tripping over tfmr's or drills, then next day the piles of tat have magically reappeared.
Andy.
29th Nov 2019, 11:36 pm | #53 |
A few that I have been waiting to do.
Restore Heathkit AC millivolt meter Restore Heathkit VOM Build ESR meter Design and build signal tracer Design and build ( probably valve) small bench amp. Transform scope type tester thing found at work into a curve tracer. Investigate Telefunken S80 amp I have had on the “in” pile for 11 months. And that’s just the stuff I can remember.
30th Nov 2019, 1:06 pm | #54 |
My next main project is to build a pre-amp/control unit for the valve stereo power amp I built some years ago. At the moment it is fed through a Quad 44 pre-amp but the new unit will include digital inputs (using a chinese DAC), line level inputs and an RIAA input. The other major project will be to build a digital organ into an exisitng console. That should keep me busy!
Bob |
30th Nov 2019, 1:18 pm | #55 |
Hi!
. . .And now I'm hopeful of adding a Speccy Analyzer to the Winter Project List! Chris Williams
30th Nov 2019, 1:45 pm | #56 |
A few jobs, having a look at my Pye Black box, it's decided to go all silent on me.
I have a lovely McMichael model 362 that I restored early this year and got working well, it needs revisiting, I changed all the wax caps but left the smoothing capacitor block, it has recently decided to fail.....should have done it first time around. I like to keep on top of my vintage stuff, 90% of it works, striving for 100%....but I know that will never happen!
Clive |
30th Nov 2019, 2:18 pm | #57 |
Ha!
You just reminded me i too have a black box to fiddle with over the winter. Its buried under a pile of Philips N1700s and in all honesty i had forgotten about it.
Oh I've had that for years dear!! |
1st Dec 2019, 11:27 pm | #58 |
Build an ESR meter.
Sort the intermittent triggering problem on the Philips scope. Repair various items of test gear before I can even start on the radios. Build an HT psi/ battery eliminator for battery sets
2nd Dec 2019, 12:26 am | #59 |
No Longer a Member
I realized one problem I was experiencing was building more and more complex projects, especially for vintage computer work and while it was fun, something happened that made me realize that building something simpler might be even more fun and remind me of why I got interested in electronics in the first place. I have built at least 4 superhet AM/SW radios in the past of varying complexity so I didn't want to make another.
Part of this was the infectious enthusiasm of another member Jolly_7 for AM radios and radios using a single IC. So I decided my Christmas project would be to build a simple MW band TRF radio in the style of a home crafted radio that a young enthusiast might have made back in the 1970's and out of materials and parts I had in the workshop. A trip down memory lane perhaps and a thought and practical experiment of what could be done with components of that era. Except its hot and summery here yesterday hit 30 deg C, so it is hardly a "winter" project. When its done I'll post it. |
3rd Dec 2019, 12:00 am | #60 |
I really must brave the cold and sort out my loft room/man cave. Not a pretty sight at the moment. I need to repair the good stuff and get rid of the junk. Easier said than done. The picture shows the tidy part.
Regards Martin Last edited by martin.m; 3rd Dec 2019 at 12:04 am. Reason: More information |
