Old 11th Sep 2019, 12:21 am   #1
Oldcodger
Default Cleaning PCB
Excess flux on a board. Scrub it, but where to find a brush . Take one artists brush ,wrap with tape and it's job jobbed. I used a 15x6 mm, which tapes up to a firm 6mm brush.
Oldcodger is offline
Old 11th Sep 2019, 1:14 pm   #2
kalee20
Default Re: Cleaning PCB
I use a toothbrush, or a cut-off paintbrush, depending which way I need to scrub!
kalee20 is offline
Old 11th Sep 2019, 1:51 pm   #3
Goldie99
It's even easier if you use an electric toothbrush....
Goldie99 is online now
Old 12th Sep 2019, 8:45 pm   #4
McMurdo
McMurdo's Avatar
I've always used an old bristle paint brush that's been given a 'haircut'. I did try a toothbrush but got tired of scraping my knuckles across cut-off component legs. The advantage of a paintbrush is that a stronger solvent like MEK or Xylene doesn't dissolve it.
Kevin
McMurdo is offline
Old 12th Sep 2019, 9:40 pm   #5
MrBungle
MrBungle's Avatar
My local art shop sells nice stubby paint brushes at 5 for a quid. I trim them too. Perfect for the job.
Agree on the knuckles issue with the toothbrush. I rather like not having road rash from cleaning a board!
MrBungle is offline
Old 12th Sep 2019, 11:02 pm   #6
Oldcodger
Mr B- must try that, but toothbrush- static problems? I've none in my circuit- it's a 7805 into an AMD 0512, but on CMOS, I'd be wary, with an electric toothbrush.
Old 22nd Sep 2019, 4:35 pm   #7
ionburn
ionburn's Avatar
I tend to run a craft knife (the blunt side) along Veroboard to clear the space between tracks then brush with an old toothbrush. If I am really trying to clear things to spotless I use a cotton bud soaked in isopropyl alcohol then brush with the toothbrush.
I do use a paintbrush for dust around components, sometimes using it with isopropyl dependant upon risk to components.
ionburn is offline
Old 9th Oct 2019, 9:09 pm   #8
whiskas
whiskas's Avatar
I use an old toothbrush + IPA, gives great results for removing /dissolving messy flux..
...where on earth did that spring/screw go??
whiskas is offline
