Old 12th Nov 2019, 2:28 pm   #61
Bazz4CQJ
Bazz4CQJ's Avatar
Default Re: Soldering Iron For PCB's
Originally Posted by ajgriff View Post
For anyone considering buying an Antex XS25 it's well worth spending an extra pound or two on the silicone cable option. The standard PVC cable is rather stiff and as a result tends to get in the way as well hampering manipulation of the iron. In addition to being heat resistant the silicone cable is much more flexible.
Alan
That's interesting. One of my reservations about the Antex is the stiff cable but I wasn't aware of the options. The old Solon irons had a wonderfully light and thin cable, but it melted quickly and probably wouldn't pass H&S requirements now.
B
Bazz4CQJ is offline
Old 12th Nov 2019, 3:07 pm   #62
I started with a big copper iron heated in the living room coal fire.
Next came a red handled Pifco electric iron (The one with a little light on a protuberance of the handle)
Then a 15W antex and a 15W antex CCN (ceramic shaft insulated)
Then the frankenstein Weller TCP made from salvaged bits and a home made PSU
Then some proper bases
Then the salvaged/repaired Metcals.
The Weller is great for larger jobs where the metcal has your hand a bit too close. I have 100W and 200W wellers.... 200W is good for plumbing with 15mm Yorkshire fittings!
For really big soldering jobs, I used to have oxy-acetylene gear which could do soft solder, silver solder and braze, but I've shifted to TIG.
If it's metal, I can join it, one way or another!
My only suggestion to the OP is to go for something good but second-hand rather than something new but not very good. The old stuff was built well and lasted well. Look around, ask around and see what turns up. Don't miss anything good if it turns up. The fancy stuff is affordable if you're lucky.
Use whatever you have to in the time being, but keep a watch out for something better.
Radio Wrangler is online now
Old 12th Nov 2019, 3:49 pm   #63
paulsherwin
paulsherwin's Avatar
Very cheap irons do have their uses. I have a market stall 60W iron which I bought for a couple of quid to do jobs which need a lot of heat. It does indeed get very hot! I added the usual switchable series diode to tame it a bit.
This iron is useless for general PCB soldering, but it's great for the odd chassis soldering job. I've no idea how long the element will last, but it's survived 5 years of occasional use.
paulsherwin is offline
Old 12th Nov 2019, 3:57 pm   #64
Bazz4CQJ
Bazz4CQJ's Avatar
I started with a big copper iron heated in the living room coal fire. David
I started with a screwdriver heated in the coal fire, soldering wires on to torch bulbs. So...you never had a Henley Solon - I didn't think that was possible? I still have a 15W model, but I suspect the leakage current could preclude its further use
B
Bazz4CQJ is offline
Old 12th Nov 2019, 10:50 pm   #65
MotorBikeLes
Like many, I started with a Solon, a 25W bought in Stafford, probably 1953. I now have Solons in all sizes up to 240W (and many others as well).
However, my point to make was that mentioned a few times here. Leakage current. I started to see little sparks quite often, and realised that was not good. Shortly after, I bought a load of broken Weller junk and a few new bits. I think I got three workers eventually, with oddments left over.
Back in my TV days, working on thyristor line Grundigs, a blanket resolder using the big Weller gun on the line stage was my key to successful reliable sets. Many bits consumed, even more solder consumed, but very few bouncers.
I far prefer a copper bit to a tinned one, so when I have a faulty tip (damaged plating), I grind off ALL the plating, and save it for a job where copper will work, but plated not.
Les.
MotorBikeLes is offline
Old 14th Nov 2019, 7:17 pm   #66
duncanlowe
Another who started with a Solon, until I got a Weller for my eighteenth (mains version with Magnastst). The Solon was my Dads. I recently got it back, along with the 'warm it up on the stove' one when helping him clear out. So those have moved to Stafford instead of from it. I do have some Oki desoldering tweezers, I wonder if I should look at getting an iron to match the power unit? We had a Pace unit at work once, it was expensive and the spares it constantly needed were expensive too. Everything is now Weller, of various models.
duncanlowe is offline
Old 22nd Nov 2019, 2:21 pm   #67
BrianAllen
Oops sorry gents, I have just seen all of the helpful posts; very much appreciated thank you.
I'm just getting used to navigating the site, hence missing your informative advice, so apologies once again.
BrianAllen is offline
Old 23rd Nov 2019, 9:42 am   #68
Diabolical Artificer
Diabolical Artificer's Avatar
Another recommendation for Antex 25w iron's. I have a Weller which sits unused mostly, just prefer the Antex. One thing I found with the Weller is it don't half use a lot of tips, whereas the Antex has had the same tip for years.
Soldering is an art, like learning anything you'll make mistakes and no doubt damage a few pcb's, it's part of the learning process.
Andy.
Old 23rd Nov 2019, 10:14 am   #69
ajgriff
ajgriff's Avatar
I wonder if Brian has been able to reach a decision regarding the acquisition of a soldering iron?
Alan
ajgriff is offline
Old 23rd Nov 2019, 12:50 pm   #70
BrianAllen
Funny you should comment Alan!
I have last week got my old Remploy out of the shed (the light blue, 35 watt, with triangular handle with little light) and the four tips that came with it; only one was ever used.
As you all are aware, they are made from copper, so with a little filing, it's looking as good as new.
I will see how I get on with practising my soldering skills but keep my eye out for a temperature controlled iron; right place at the right time springs to mind.
Brian
Old 23rd Nov 2019, 1:19 pm   #71
ajgriff
ajgriff's Avatar
Excellent and Happy Soldering!
Alan
ajgriff is offline
Old 23rd Nov 2019, 1:20 pm   #72
BrianAllen
Thank you kind sir.
Brian
