1st Sep 2022, 10:39 am | #1 |
Roberts, RT1
I switched the set on after a few years of inactivity and was greeted with a loud hiss/ buzzing sound not a station heard. Then I realised the volume control was set low. When I raised the volume, stations could be heard above the constant level of noise.
So the fault must be after the volume control, possibly a noisy transistor or resistor. The driver transistor was an OC71 which are not beyond suspicion at 64 years old. And the output are a pair of OC72. I sprayed the OC71 with freezer spray and the level of noise dropped a bit. Before I remove it I put my signal tracer on B then E of the OC71 Driver clear, no noise, then on to pin C and was "rewarded" with a loud noise. I replaced it with a NOS OC71, which worked well, but I am aware these glass transistors can fail by going noisy. It tested as 2 Diodes. John.
My favourite text message "I'll be there in five minutes, if not read again" |
