Websites Found an interesting website? Post the details here and share it with the rest of us. Please stick to websites that are in some way related to our hobby/interest. |
24th Aug 2022, 4:12 pm | #21 |
Re: Ladybird Book Making a Transistor radio
I met someone who had built one of these radios, properly on a piece of wood with the screw-cups etc.
The postage stamp trimmer had a length of plastic knitting needle glued to the screw head. I think that the audio stage was rather weak. As you say poor biasing. This person had used OC81's and selected those with the best gain. The radio was in a case that had two transparent sides. The tuning capacitor had a reduction by means of a cord drive which went around the case and included a needle and scale! I wonder if the radio could be made with Russian transistors? |
25th Aug 2022, 9:21 am | #22 | |
So I decided to build a nice veroboard version, fixing the ferrite rod onto the edge of the board with wire loops. Oh dear. The time wasted in trying to find out why it was not working was monumental, and of course the board became more and more scruffy as I removed parts for testing time and time again. Inspiration came at school in the middle of a biology class, and I couldn't wait to get home to snip the loops. It worked! I never forgot THAT lesson....
Andy G1HBE. |
25th Aug 2022, 6:36 pm | #23 | |
I fairly recently had to sort out why a battery valve set was very deaf. It had (so I was told) recently been serviced by a radio engineer. Peering inside, it took me a couple of moments to notice that the ferrite rod had been repaired.....with a metal collar around the middle that had been Araldited in place....! Fortunately I had a suitable rod in my box of bits and the radio was soon back to normal after a quick realignment.
25th Aug 2022, 6:52 pm | #24 |
There's currently a display of Ladybird books at the old Music Hall Museum in Shrewsbury.
In a special display there is a copy of the Transistor Radio book, complete with a built breadboard radio. David. |
26th Aug 2022, 2:04 am | #25 | |
The biology lessen must have been about how muscles work and the light bulb moment happened when he realized that muscles needed to be used to squeeze the handles of the cutters to snip the wire loops |
26th Aug 2022, 2:15 am | #26 |
heh hehe it was the muscles in his head
Joe |
26th Aug 2022, 5:45 am | #27 |
The most powerful muscle of all.
26th Aug 2022, 11:35 am | #28 |
A purely random thought, the kind that happens when you're not paying attention to anything much!
Andy G1HBE. |
26th Aug 2022, 12:26 pm | #29 |
Erm... isnt the detector diode on page 31 the wrong way around for the PNP ?
[ducks below parapet...] |
26th Aug 2022, 7:31 pm | #30 |
I thought that too!
There's quite a few things that leave something to be desired... the potential divider biasing WITHOUT emitter resistors... the bare-wire mounted ferrite aerials... Phil G's backward-connected diode... I seem to remember seeing an edition which used a 'gimmick' capacitor for regeneration, two short lengths of insulated wire twisted together. The picture showed... stripped wires twisted together! It's not up to the standard that one would expect of a 'teaching' book, which is a shame because the artistic standard of the illustrations is high. But if the technical standard isn't, it's a let-down! |
26th Aug 2022, 10:59 pm | #31 |
I think I remember the "Tinytone" (or was it the Terrytone?) Radio Control receiver used twisted wires for a tunable few pF to set the superregeneration
26th Aug 2022, 11:56 pm | #32 |
28th Aug 2022, 3:06 pm | #33 |
Thinking further, in 1972 when the book was published, a ZN414 radio would have been easier to build, easier to document, and would have had a far superior performance...
29th Aug 2022, 2:05 am | #34 | |
Easier, easier, superior... That's not how it works, at least not for me Steve.
29th Aug 2022, 3:25 am | #35 |
You are absolutely right Steve. Painting by numbers does not a Michelangelo make.
Like using a calculator for your shopping, If you can't add up simple math, don't try electronics. Joe |
29th Aug 2022, 10:40 am | #36 |
29th Aug 2022, 12:14 pm | #37 |
Over on Abebooks website, they have available another copy of the book. https://www.abebooks.co.uk/servlet/S...=9780721403243
Only this time it's a Learnabout title again by Rev. Dobbs. You can see the Ladybird in the bottom right corner of the book so it's probably exactly the same. The publication date is also 1972 like the Ladybird version. I don't suppose the Learnabout version addressed the errors. Also by Rev. Dobbs, there's another Learnabout title, Simple Electronics. https://www.abebooks.co.uk/products/...=pd_detail-1-v Not sure if there was one with the Ladybird title. Regards, Symon. |
29th Aug 2022, 12:26 pm | #38 |
I don't think any of the projects I built from books, magazines or kits worked first time. In fact some of them never worked at all. I did learn a lot getting them to work though.
30th Aug 2022, 5:55 pm | #39 |
I never did the Ladybird book radios but there was a better book which I kept taking out of the local library, I forget the author but it had a green cover and led you through a succession of radios from a simple crystal set, a reflexed MW transistor set, and different audio stages [headphones or a Class A transistor amp using an OC72 through to a push pull Class B version ].
The end version from what I recall was a SW regen design covering the 41 and 49 Metre bands. Was it maybe authored by R.A. Penfold??
30th Aug 2022, 6:35 pm | #40 | |
Regards, Symon |
