View Poll Results: Will the radio work when turned on at 4PM? | |||
YES | 2 | 10.00% | |
NO | 18 | 90.00% | |
Voters: 20. You may not vote on this poll |
6th Nov 2021, 9:18 pm | #61 | |
Re: Pilot Little Maestro restoration project.
The problem i'm having with replacement caps is the price, Can buy a pack of ten polyprop all the same value for about £4, But all the values i need vary, Next job is testing the resistors, Getting there bit by bit. Thanks simon Jay
Help!! I've been electrocuted by a glass thing that glows |
6th Nov 2021, 9:32 pm | #62 |
The only other electrolytic besides the smoothing caps, I might have one i can use but wont have a high voltage rating, So i'll need to see what voltage is present at that point,
Cheers Jay.
7th Nov 2021, 2:09 am | #63 |
I Have 4 X 100 OHM 100 WATT Aluminium power resistors that i'm thinking of combining to obtain the correct HT Voltage. The shocking plan is this.......
Get a piece of mains wire and connect 2 X of the above resistors in series (200ohms) and put them in series with the mains cable live. And measure the voltage.. What voltage should the rectifier see at its plate(s) ? 200 volts ?
Help!! I've been electrocuted by a glass thing that glows Last edited by Radio Scotland; 7th Nov 2021 at 2:28 am. |
7th Nov 2021, 10:41 am | #64 |
Resistor values, Tested in situ, Tested values on the left, What they should be on the right.
Not looking good
7th Nov 2021, 12:25 pm | #65 |
I forgot to say that C12 should be rated at 1000V as the output transformer has voltage pulses higher than the HT line.
C11 doesn't have to be a high voltage type, the original working voltage should be marked on it and was probably 25V. Post 63 - that test won't work! your meter will likely have a resistance of 10M and will just show the mains voltage if no current is being drawn. 470 ohms is a good starting point and you will be looking for about 200V dc between cathode and chassis. I suggest you start by not connecting anything to the anode and get the valve heaters and scale lamp working properly first. Post 64 - the resistors were mostly 20% tolerance and don't have to be exact. If they measure high in the circuit then they have drifted high but if they measure too low then this may be due to another path. R3 is significantly high. R5 reads very low, this is probably due to leakage in C8. R9 reads low, this is probably due to leakage in C11. |
7th Nov 2021, 1:01 pm | #66 | |
Yeah i didn't think that test would work without a load, Plan was just to do a mock up circuit to check voltages, I don't wanna get the heater voltages wrong and pop them, Yes that was my plan, Get the heater circuit working with no anode voltage applied. So what resistors would you change ? Thanks Again. Jay.
Help!! I've been electrocuted by a glass thing that glows Last edited by Radio Scotland; 7th Nov 2021 at 1:05 pm. Reason: Additional info |
7th Nov 2021, 3:05 pm | #67 |
Hello all. as others have said probe leave resistors alone (poss r5 may be a problem) i have tacked in a modern in parallel to get one down to near)
grid coupling a recommended change. for testing i have used just 650 volt caps, caps power resistors do not need to be in the set. i use fly leads poss a bit cardboard for safety i think its best to try to get radio type noises from set.THAT always makes me happier, if you change many components and set not work. Thats not good dave |
7th Nov 2021, 3:54 pm | #68 | |
Cheers. Jay
7th Nov 2021, 10:12 pm | #69 |
Turns out R5 is 13.7M, wasn't getting a good connection first time i measured it, R9 Is 350 ohms even with C11 Disconnected which is dead.
Schematic shows C11 As a 10uf electrolytic, But its actually a big wax bomb
8th Nov 2021, 12:08 am | #70 |
Must be a dry electrolytic, I'll re-stuff it tomorrow,
8th Nov 2021, 1:55 pm | #71 |
Got most of the parts on order, But need to know what type of capacitor i need for C12 (Tone correction) ? I know the value and voltage rating, But unsure of the actual type needed ?
8th Nov 2021, 5:40 pm | #72 |
Any .02uF 1kV non-electrolytic type would be ok but there don't seem to be many that are sold singly these days and those that are seem to be ceramic types, here's one example:
https://www.mouser.co.uk/ProductDeta...xfWiv%2Fk0w%3D Another thing to be aware of when buying resistors is that even if the wattage seems suitable they are not all rated for higher voltages. Here is one example that is rated at 350V: https://cpc.farnell.com/tt-electroni...0k%20resistors |
8th Nov 2021, 5:59 pm | #73 | |
I Can get a ceramic type on ebay, But didn't think they were suitable for audio circuit application. Didn't know resistors had a voltage rating, Learn Something new everyday as they say. Iv'e restuffed C11 With a 10uf ..50 volt capacitor audio output cathode bypass, According to your earlier post anything above 25 Volts should be ok ?? Cheers simon, Jay
Help!! I've been electrocuted by a glass thing that glows Last edited by Radio Scotland; 8th Nov 2021 at 6:10 pm. |
8th Nov 2021, 9:06 pm | #74 |
Yes, that will be fine and looks much better than a modern component.
Next step is to get the valves glowing! |
8th Nov 2021, 9:12 pm | #75 | |
Cheers for all your help Jay
8th Nov 2021, 9:16 pm | #76 |
Meant to say - Evox Metallized Film Capacitor 22nF 1000V 5% ordered for tone correction.
8th Nov 2021, 9:20 pm | #77 | |
I've come across 0.01uF ceramics as audio coupling caps on several occasions.
8th Nov 2021, 9:41 pm | #78 | ||
Jay
9th Nov 2021, 4:13 pm | #79 |
Tested all the wax bombs (in situ) and all give a reading albeit sky high. Only open one was C11 Since restuffed.
Problem is with restoring one radio and buying parts one at a time is costs quickly rocket. I have a spare 22nf ..1000 volt capacitor, Could it be used to replace any of the remaining waxies ? I know value isn't super critical. As mostly coupling/decoupling. Remaining wax bombs C4 - .05UF C6- .05UF C7- 0004UF C8- 005UF Cheers Jay
10th Nov 2021, 1:02 pm | #80 |
HT Resistor- 10 watt rating Really ?
