Old 25th Apr 2021, 11:07 pm   #21
Analogue man
Default Re: Crompton 60W bulb
Originally Posted by Tom williams View Post
Hi all,
I own a Crompton 60W bulb as part of my vintage electrical fittings collection, and was wondering what it is used for, it is bright red, the only things I can think of it being used for are as follows:
The flashing red lights you see at level crossings.
As part of one of those strings you see hung up at events.
If there are any other purposes for this bulb, can you please let me know as it is quite an interesting subject for me.
Tom
The flashing lights on a level crossing were until recently 24v 36w clear lamps shining through a red lens. These days most have been replaced by red LEDs.
Analogue man is offline   Reply With Quote
Old 26th Apr 2021, 10:16 am   #22
Heatercathodeshort
Heatercathodeshort's Avatar
Getting a bit deep here! LOL As W1 has mentioned it is just a coloured light bulb for decorative effects. I used to stock all the colours in 25W and 60W. High demand at Christmas, parties and weddings etc.
I think 25W was the maximum for outdoor use. They were also available in ES, SES and SBC holders.
The old fairground lamps were for 110V fed from DC dynamos. They are mostly LED now fitted into large plastic shades to resemble the old filament bulbs.
I have a large collection of vintage bulbs going back to around 1905. You would not believe the different types and colours available. The lamp business was a BIG one. John.
PS Ancient Amber 100W lamp still in use in my collection shed. J
Name:	Amber lamp (2).jpg
ID:	232640   Click image for larger version
Name:	Amber lamp (1).jpg
Last edited by Heatercathodeshort; 26th Apr 2021 at 10:28 am. Reason: Info and pics added.
Old 26th Apr 2021, 11:36 am   #23
kellymarie
I have several 25 watt colored bulbs in use in my disco room they are Cromton 25 watt bulbs for 200/250 volts they are all ES types guess how I found out that the outer metal screw part was live! My faveroute bulb is a sort of deep orange peach color. In keeping with a vintage theme they are powered via a collection of 2 pin 5 amp plugs into an adaptor in a 2 pin socket. Does anyone know if colored flu lamps still exist or is is possible to color a white tube? Thanks guys
kellymarie is offline   Reply With Quote
Old 26th Apr 2021, 11:58 am   #24
emeritus
When I was a student I made my own coloured bulbs using sprit-based permanent marker pens.
emeritus is online now   Reply With Quote
Old 26th Apr 2021, 12:17 pm   #25
Bazz4CQJ
Bazz4CQJ's Avatar
My collection of red lamps consists of a 15W Mazda and a 60W Thorn. Both are 200/250V. Are they rare?
B
Data beats opinions most times... that's my opinion, though I have no data on that.
Bazz4CQJ is offline   Reply With Quote
Old 26th Apr 2021, 1:20 pm   #26
Some lamps were specified as being "fire lamps" I remember Woolworths selling them in the early 1970's.
"Magicoal" seems to ring a bell regarding the electric fires they were used in.
Keep the soldering iron hot.
Old 26th Apr 2021, 2:25 pm   #27
duncanlowe
They were used in many things, and also in gas fires. My Baxi Bermuda had one either side in pockets.
We also used a firelight bulb in a mockup campfire for Cubs and Scouts for 'indoor campfires'. Blue Peter did soemthing similar, but theirs became an actual fire, if anyone remembers that!
duncanlowe is online now   Reply With Quote
Old 26th Apr 2021, 2:44 pm   #28
emeritus
I bought a set of 10 assorted 25W coloured GLS bulbs (by GE) from Screwfix when they were clearing their stocks of tungsten lamps at bargain prices. Still haven't used them yet! They are translucent like the OP's one, as opposed to transparent. All the red fire bulbs I have seen have had a clear red lacquer colouring.
Old 26th Apr 2021, 3:02 pm   #29
Tom williams
Tom williams's Avatar
Originally Posted by John_Dw View Post
Probably a 'vintage' heavy duty bulb designed for use in old fashioned decorative lights, think Christmas or Blackpool....If you hold it up to a strong light source can you see how many supports are on the filament? I would suspect at least six spread over 300 degrees or more....
Hi John,
After just having a look, it turns out that there are 9 supports including the two powering the fillament.
Tom
Tom williams is offline   Reply With Quote
Old 26th Apr 2021, 4:48 pm   #30
broadgage
Coloured fluorescent tubes still exist, often in red, yellow, blue, green, and pink. The blue, green and pink lamps usually use a coloured phosphor, the red and yellow lamps are coated white ones.
Coloured compact fluorescent lamps are now hard to find but do turn up on ebay.
You can colour your own CFLs by dipping them in coloured gloss paint of the desired colour. Light the lamp afterwards for an hour or so to bake the paint onto the glass. Do this outside just in case a fault ignites the paint. Once the paint is thoroughly dry the lamps can be used safely.
Coloured LED lamps are rapidly taking over, red, blue, yellow, and green are readily available, and other colours exist.
broadgage is offline   Reply With Quote
Old 26th Apr 2021, 5:40 pm   #31
merlinmaxwell
merlinmaxwell's Avatar
Darkroom lamps where made of red glass obviating any chance of a white light leak. Very under run to prolong life and no need for any blue light anyway, just as well they as where not cheap. Somewhere I have one I got second hand in 1970...72 when I got it for my teenage darkroom. Then I discovered the sodium street lights did a better job (at night) and for no cost!
Old 26th Apr 2021, 5:56 pm   #32
broadgage
Back in the day, lamp makers offered "natural coloured" lamps. This referred to lamps made of coloured glass rather than clear glass lamps coated internally or externally with paint etc.
The red lamps were more expensive than other colours, this because red glass contains gold, in contrast to the base metal compounds used for other colours.
In the days before good quality fire resistant colour filter materials, much use was made of natural coloured lamps for theatre lighting.
Old 26th Apr 2021, 6:00 pm   #33
Stuart R
Stuart R's Avatar
It's not a 'Fire Glow' bulb, they were clear and agreed, seemed to be a dark orange rather than red.
If I remember correctly, some Fire Glow bulbs used a 3-pin BC base (two electrical contacts but three locating spigots sticking out the side of the base). Were they hotter and this was to stop them getting put within (paper) lampshades?
I remember having to change the bulb holders on a Great Aunt's Berry Magicoal fire when 3 spigots became hard to come by in the 1980s.
SR
Stuart R is offline   Reply With Quote
Old 26th Apr 2021, 7:23 pm   #34
Heatercathodeshort
I used to sell a lot of them! With the fires that used two bulbs the old girls used to come in the shop and ask why they both failed together. I used to explain that one probably failed weeks ago and you had not noticed. They never believed me.
The two prong fireglow lamps are pre war Berry's magicoal. The post war Berry's is the 3 pin bayonet. Most fires including the Belling employed the standard BC base.
They are single coil 60W types. Maybe Berry's used the 3 pin type to restrict guys from putting in just any old coloured lamp, spoiling the effect or maybe just to charge a bit more for the 'special' lamp. They did not get any hotter than a standard 60W lamp.
When I was first in the trade you could buy stained red glass lamps but they were twice the price of the standard lacquered type that cost 2/6d around 1964. Older people appeared to have a fetish about light bulbs often asking for strange types, finishes, and colours. I stocked the lot! They often called them globes and I had one lovely old dear that called them 'electric mantles'.
Regards, John.
ID:	232684   Click image for larger version
ID:	232685   Click image for larger version
Old 26th Apr 2021, 7:44 pm   #35
Megatron
www.lampwise.co.uk
Still sell the full range of coloured lamps in 60W.
dont think it is a special lamp. probably modern if it has an aluminium base.
Megatron is offline   Reply With Quote
Old 26th Apr 2021, 9:44 pm   #36
kellymarie
I will try coloring an ordinary flu lamp using marker pens see what happens advice about powering it up outside is noted it should certainly get my nosey neighbors talking. The 3 pin base fireglo bulbs were about when I restored an old electric fire in about 1981 must admit I was chuffed to find a suitable bulb in a local electrical shop those bulbs kind of had what I call a toffe apple color to them I never tried licking one tho I may be mad im not crazy
Old 26th Apr 2021, 11:43 pm   #37
broadgage
Still some availability of coloured CFLs on ebay. I suspect that production may have ceased and that availability will decline as LEDs take over the world.
Old 27th Apr 2021, 2:33 am   #38
Lancs Lad
Lancs Lad's Avatar
I was given a couple of these pink Crompton lamps/bulbs several years ago. They've never been used, still in original boxes.
They're nice to have - and I've no intention of just throwing them away - but I have no idea what I will ever use them for...
ID:	232719   Click image for larger version
ID:	232720   Click image for larger version
Best Regards,
Peter.
Last edited by Lancs Lad; 27th Apr 2021 at 2:46 am. Reason: Additional comments and grammatical improvements!
Lancs Lad is offline   Reply With Quote
Old 27th Apr 2021, 6:53 am   #39
kellymarie
Looks like the ones above are the BC version of what I have mine are all ES thats just what I was given and yes first thing I checked was that they weren't 110 volt US lamps
Old 27th Apr 2021, 6:21 pm   #40
rambo1152
rambo1152's Avatar
Looks like the ones above are the BC version of what I have mine are all ES that's just what I was given and yes first thing I checked was that they weren't 110 volt US lamps
Twenty years ago I would have done the same, but these days ES lamps seem to have overtaken BC ones going by what's on sale.
The malaise started with stores like Ikea, but has spread to the likes of Tesco Asda and Sainsburys etc.
I beg to report that all the light fittings in my house are still Bayonet Cap (with the solitary exception of the one in the downstairs toilet which a builder managed to sneak in under the radar).
All's well.
God save the Queen.
Graham.
G3ZVT
