Bush TR82 - general transistor bias question
In the Bush TR82, in the pre-amp stage TR5, the voltage at the collector (output) is marked as 8.3V off a 9V battery.
Ref: https://www.vintage-radio.net/forum/...3&d=1386851936 Why is that voltage so high? If you wanted a nice large clean voltage swing, surely you would have it closer to 4.5V? |
Re: Bush TR82 - general transistor bias question
It's because it's driving a transformer primary rather than an actual resistor. This means that the collector can swing dynamically as far above the 9V rail as it can swing down before it hits the emitter voltage level.
The transformer coupled output of a typical valve set behaves in the same way with the standing anode voltage sitting as near HT+ as the primary resistance voltage drop allows. |
HERALD1360 thank you for the explanation, very helpful. I'll do some more reading on that. Thanks you.
