Taylor 68A alignment.
Has anyone ever done a calibration of the scale and bands on one of these?
The one I have works perfectly, the only time I have been inside it was to change out the Belling-Lee for a reliable N-type RF connector. I noticed that the scale is a bit out on some bands, especially the low ones, is it an easy job just to tweak the coils and get the scale to read correctly? |
Re: Taylor 68A alignment.
The old workshop sig gens were not at all precision instruments, nor did they have particularly fine tuning. In % terms what is a "bit out"? Is this for your 1977kHz project?
B |
My 68A, set as close as I can to 2000kHz, is actually radiating at 2010kHz, though it is still warming up. I think that's pretty good for that type of sig gen :). As for re-alignment, maintaining the tracking is the key issue and I've not tried it on this unit.
B |
Calibrating your Taylor should be straightforward. I was able to calibrate my Advance E2 earlier this year with a frequency counter. I'm confident to say that it is more accurate now than when it left the factory.
You'll need to identify which capacitor/coil pair sets each band. Lining up the pointer and dial might be tricky; I have not seen the inside of a Taylor so I can't comment. If it is anything like my E2 your Taylor might just need a long reach screwdriver to undo the pointer. |
I left mine on for 3 hours night and it barely moved as it warmed up on 2010kHz. They are a very good old workshop sig-gen. I have been inside, but not to change alignment. B |
I don't mean fault sort of wavering. I mean between the ranges, 470kHz was 467 on the scale, 1.8mHz was 1.9 on a different scale, same on 3.5mHz was 3.6 on another scale, just little niggles, too perfectionist???
