144 Mhz Cubical quad SSB end
I'm back on it again a year later! Hoping to get this aerial working for some SSB operation on a lift, there have been some reports of some very good VHF propagations during this hot weather.
However following a design page where the frequency is typed in and you magically get the correct dimensions and spacing it flopped dramatically. I adjusted the driven element so it is now 70mm longer in total length and re-spaced the gamma match, it now appears to work well but i'm not sure about adding a tuning stub to the reflector or how this thing should be adjusted as a procedure ie steps 1 2 3 etc . So are there any VHF gurus out there who have cubical quad experience? |
Re: 144 Mhz Cubical quad SSB end
I love it when the empiric triumphs over sums :dunce:
IIRC, 73 Magazine and QST both had articles on cubical Quads back in the early 70's.
HTH. (Mine are all packed away, so I am unable to look through them.) |
Thank you for the replies i will give QST a look .
Cant imagine my antenna building skills are this good because i,m getting almost 1.1:1 in the SSB part of the band . |
David |
Definitely experimental here LOL.
I'm a 'RHINO' these days (Radio Ham I Name Only), but when I was active on air (up to 2003) I made all my own antennas for VHF and HF.
Back in the late 70s (I was licenced in 1977), I made a 'Quagi' Quad Yagi for 2 Meters which performed very well. At the time, I lived in North Lincolnshire, and often had QSOs with Dutch amateurs as there was a fairly clear take-off across the North Sea. Back then, most 2 Metre activity was on SSB, and the 'Liner 2' was much in vogue. (A step up from using modified ex PMR Pye Cambridge AM rigs, 'tuning high to low', which won't mean much these days). Full constructional details including dimensions for various frequencies are here: https://www.amateur-radio-wiki.net/quagi/ A bit more about the theory and design here on Youtube: https://www.youtube.com/watch?v=XhuRCV3ZxW4 And here: www.overbeck.com/quagi.htm Hope that's of interest. |
Thanks Dave, i will look at the links you sent . Every aspect of this hobby is so interesting.
I have yet to hear SSB DX on 144mhz , heard plenty on 50mhz on the home made quad . I chose a quad as i thought it had some attributes the yagi seems not to have , as far as the text books say !. Mechanically it has a character of its own , a bit of a beast to assemble and take down. I wonder what has changed between the 1960s and today regarding solar activity and its effects on earths atmosphere and the layers. I dont know whether its my imagination but there seemed to be so much more on the air in the 70s , |
