Reply
Old 22nd Aug 2014, 10:59 am   #181
SteveCG
Default Re: 405-Line VHF Aerials in 2013-2014
Re: post no. 180,
Brian you are correct - I reckon the bungalows were put up in about 1967/8 from their appearance. As you say it is suprising about the non-removal. The little 'contractor cheapo' UHF aerial on the old pole points to the Malvern relay, as does the UHF aerial on the new pole. I think there was a community type distribution system between groups of the bungalows. There were at least 4 different Band I, Band III systems on this estate - all made by J-beam and all different !
SteveCG is offline   Reply With Quote
Old 2nd Sep 2014, 10:50 pm   #182
al the bushman
For your perusal.
Spotted in Bridlington town centre near the harbour, an innocent looking horizontal array pointing south. Then I thought "wasn't Belmont (station of choice in Brid) vertically polarised?" Not only that, Belmont didn't broadcast on band I...
Which begs the question, what service did it receive when erected? Facing the wrong way for Scarborough - could it have been pre-Belmont picking up fringe reception from Mendlesham/Tacolneston?
ID:	97097   Click image for larger version
ID:	97098   Click image for larger version
al the bushman is offline   Reply With Quote
Old 2nd Sep 2014, 11:33 pm   #183
AC/HL
AC/HL's Avatar
And who installed that one next door?
AC/HL is offline   Reply With Quote
Old 3rd Sep 2014, 10:02 am   #184
Tazman1966
Tazman1966's Avatar
I get the feeling that the oddly mounted UHF array was probably an 18 element one before snapping in half. If not, it certainly is an odd way of mounting it!
All the very best,
Tas
Tazman1966 is offline   Reply With Quote
Old 3rd Sep 2014, 10:14 am   #185
Brigham
Mendlesham/Tacolneston would make it Ch.3/11, which looks about right. It's a long haul, though. Was it known in the area?
Brigham is offline   Reply With Quote
Old 3rd Sep 2014, 3:34 pm   #186
SteveCG
Both combined BI & III are by Antiference, dipole - director designs.
If as said (and the sun shadow in the second pic rather confirms this), the aerials are pointing south then Medlesham/Tacolneston would fit the direction. However as Brigham says it's an awfully long path - and at that distance I would have expected separates: a 4 element Band I and double 8 for Band III. The only other H-pol, Band I Tx in that rough direction was Peterborough on channel B5.
I wonder what the H-pol UHF transmitter is for the UHF aerials in the pictures? They all seem to be 10 el designs, so hardly fringe reception.
Old 3rd Sep 2014, 4:40 pm   #187
steve1010uk
The 10 element UHF's are aimed at Belmont, path is partly over the sea but works well most of the time
steve1010uk is offline   Reply With Quote
Old 4th Sep 2014, 11:26 am   #188
SteveCG
Thank you steve1010uk.
Now I wonder why the Antiference combined aerials are pointed at it? As has been pointed out Belmont 405 was Band III only, vertically polarized on channels B7 and B13. So if it was a case of using existing aerials for the 'new' service from Belmont then I would have thought that (if you were going to the trouble of going onto the roof) they would have been turned to be V-pol as well as pointing in the 'new' right direction. On the pedants side, one can also debate how well the Band III parts would have worked on channel 13.
Old 4th Sep 2014, 11:49 am   #189
Brigham
I'm now thinking it's Peterborough Ch5 (H). It looks very similar to our local Ch5/8 combos for Pontop Pike/ Burnhope.
What would the ITA transmitter be?
Old 4th Sep 2014, 11:58 pm   #190
Hybrid tellies
Hybrid tellies's Avatar
The ITA transmitter could be Sandy Heath which used ch6 with horizontal polarisation. I find it hard to believe that the 1kw Peterborough band 1 signal would put a usable signal into Bridlington. Also Sandy Heath opened within a short time of Belmont in 1965.
This aerial does look similar to my VF100 VHF DX TV aerial I have in my loft. Pointing south or southeast into south and central Europe is about right.
Simon
BVWS member
Hybrid tellies is offline   Reply With Quote
Old 5th Sep 2014, 7:49 am   #191
Focus Diode
Focus Diode's Avatar
Post #182 is fascinating by the distance involved. It does indeed resemble our Pontop/Burnhope Ch5/8 combined type.
The BIII aerial appears to have shorter elements suggesting ch11 Mendlesham. On looking at the IBA VHF coverage map the nearest horizontal transmitters would appear to be Burnhope and Pontop Pike! Mendlesham had 200kW ERP where our Burnhope had 100kW.
Certainly such long distance reception could/would've been possible with the unobstructed sea path though one would've thought more elaborate aerials would've been needed. Tacolneston ch3 was only 45kW, then Pontop Pike was only 17kW which covered remarkably long distances considering.
Cheers,
Brian
Name:	VHF Television coverage  ITV 75 part.jpg
Focus Diode is offline   Reply With Quote
Old 5th Sep 2014, 1:11 pm   #192
FERNSEH
FERNSEH's Avatar
Originally Posted by Focus Diode View Post
Post #182 is fascinating by the distance involved. It does then Pontop Pike was only 17kW which covered remarkably long distances considering
Was the original function of the 17KW Pontop Pike Ch5 transmitter a relay station for Holme Moss?
DFWB.
FERNSEH is offline   Reply With Quote
Old 5th Sep 2014, 2:37 pm   #193
SteveCG
A thought concerning the Bridglington aerials:
They've most likely been pushed off their top of their poles by the UHF aerials. so is there any chance the only reason that they are horizontal now, that it was to stop them snagging the UHF aerials?
Could they originally have been for Holme Moss and Emley Moor? (ie Chs B2 and B10, both vert pol). Not knowing that part of the country I don't know what the signal strength in Bridlington was from HM & EM. However my gut instinct is that the Band I elements are too short for B2...
Old 5th Sep 2014, 6:47 pm   #194
steve1010uk
There's another very similar aerial in Bridlington, horizontally polarized just the same, i will try get a pic of it soon,
i have been puzzling over where these were pointing at, i wonder if there was some low power VHF relay station somewhere near Hull but can find no mention of one
They are not directed at Holme Moss or Emley as both are over to the west,
these aerials definitely point south
Similar aerials are mounted with horizontal polarization just up the coast at Scarborough but these are aimed at Olivers mount relay in the town
Steve
Old 5th Sep 2014, 10:17 pm   #195
colly0410
Wonder if it was on Olivers Mount originally & swung round to Belmont, but the person doing it didn't know that Belmont was vertical polarisation, just a thought..
colly0410 is offline   Reply With Quote
Old 6th Sep 2014, 11:24 am   #196
SteveCG
Re post no. 194
I, for one, will be interested in any further pics of BI & BIII aerials in Bridlington.
Scarborough 405 was on channel B1 - and I would put a small wager on the idea that the aerials we are discussing are not B1 - far too short !
As for Peterborough on B5 - well I reckon that with Pontop Pike also Hpol and also on B5 then the co-channel interference in Bridlington would have been pronounced.
BTW, yes I am happy with the point that the aerials are now Hpol and point south - but were they always that way? is the question.
It certainly a 'teaser' this one!
Old 6th Sep 2014, 11:43 am   #197
yampy187
yampy187's Avatar
Hi all. This may be of interest. I've just moved into a new flat and this is what I found!! Not exactly a B1 aerial but I think it's attached to one somewhere? Is this an aerial diplexer of some discription? (See photo) one of the valves had gone to air!!
Jan
yampy187 is offline   Reply With Quote
Old 6th Sep 2014, 12:11 pm   #198
SteveCG
Looks more like a distribution amplifier - perhaps to feed TV signals to all the flats? Indeed expanding the pic and putting a 90 degree crick in my neck, I think it says Distribution Amplifier on the manufactur's ident plate.
Old 6th Sep 2014, 12:39 pm   #199
Restoration73
Restoration73's Avatar
T.I.S. - company still trading
http://www.tis.co.uk/
Restoration73 is offline   Reply With Quote
Old 6th Sep 2014, 1:19 pm   #200
ianhumph
ianhumph's Avatar
Might this be of use? I resized just the plate area x5.
(Requires a click!)
I used to be indecisive; now I'm not so sure......
ianhumph is offline   Reply With Quote
Reply
