| Vintage Audio (record players, hi-fi etc) Amplifiers, speakers, gramophones and other audio equipment. |
#1 |
Hi everyone, the Linear Conchord 30 watt amplifier was very common in the 60s/early 70s and was sold ready made or in kit form by RSC Hifi centres all round the country and was very popular. The ready built versions used the
EL34 output pentode but the kit form used the 807 tetrode valve which at the time was plentiful in the surplus market. Its original use was as a transmitter PA valve I believe. My question is, does anyone have a copy of the original circuit diagram of the RSC/ Linear amp using the 807? It used a different biasing arrangement to the EL34 versioin. Im not interested in the PW version as I think its inferior. My intention is to build a stereo valve amp of approx 40w per channel using the 807, with some circuit modification to improve performance. Any advice or assistance would be welcome. Bill |
#2 |
Hi Bill, I have a Geloso version of this type of amp using 807's and it sounds very good. It runs at about 450v on the anodes and the fixed bias is approx -36V.
Ed |
#3 |
Hi Bill,
The early Vortexion 50 Watt amplifier used 807 valves. I’ve attached the circuit if it helps. Sadly there are no voltages marked on the diagram. I’ve seen a fixed bias circuit for a 75 Watt 807 amplifier in one of the Brimar Valve and Teletube manuals. Maybe if you think it's of interest I’ll see if can find it and scan it for you? Terry. |
#4 |
Thanks lads, Ed, I've got a mains tx that will put 450 or so on the anodes, the 807 will take a high voltage. What I need most of all, is the biasing arrangement using a standard type mains tx, ie 450-0-450 6.3 5.0, I'm aware that the concord used a standard tx but the centre tap was lifted from ground to give the bias for the 807. Terry, if you could send me the schematic for that amp I would appreciate it, I can pm you with contact details. Many thanks.
Bill |
#5 | |
No Longer a Member
Hope this is of some use. Lawrence. |
#6 |
I've got a schematic I traced from an actual amplifier that I own awaiting renovation.
#7 |
Hi Bill, the bias supply can be derived from a resistor in the centre tap, but it is not a good design.
By far the best way is to use a small (say 5va) transformer to derive about 50 volts, even voltage doubling to get a higher output is OK, as the current requirement is so low. If you want the Geloso circuit PM me with your e-mail and I'll send you a scan. Ed |
#8 |
Hi Tony
That is a very nice drawing you have produced. What drawing program did you use? Please use this link to a new thread for your reply, to avoid taking this one off topic. http://www.vintage-radio.net/forum/s...703#post464703 Regards Colin
Integration spells frustration; But plain discreet is rather neat. |
#9 |
Tonyharker, thats the one! Nice drawing too, thanks for posting that. I recall though, that the smoothing capacitor on mine was only a 32uf 450v component isolated from chassis) Also your version employs far more smoothing components on the ht rail than I ever remember! Its true that this was not a 'quality' amp, it used cheaper components and transformers, however I do still own a couple of them which use EL34s and I have to say they do actually sound quite good. (I remember some years ago, I used 2 of these amps for the school dances etc and there was plenty of volume in quite a large hall through large banks of 12" speakers) Although far from HiFi! there is far too much hiss mainly from the high gain circuitry of the EF86s. My intention now is to construct from scratch, a stereo version using 807s, high quality transformers and improved circuitry. I think the suggestion re the seperate biasing transformer is a good one, although Im not sure what effect this may also have with crosstalk. Anyone any ideas?, also suggestions for circuitry would be appreciated.
Bill |
#10 |
In these days I'm working on a Linear L50, on which I've experimented stabilized B+, with astonishing effects on dynamic range - I'll talk about it in a separate thread. I too had too much hiss but cured it removing the cathode bypass capacitor on the first EF86.
Cheers Marco |
#11 |
Hi Marco, that sounds really interesting and it would be nice if you could share that design here with the lads on the forum, also I would love to see that schematic if you could send it to me.
Bill |
#12 |
Thank you Bill,
as I've said I'm going to start a new thread on it this evening. However I'd like to anticipate a shot of my "Blue Linear": the added radiator hides a BU931 darlington. Marco |
#13 | |
I used one of of these and two EL34 variants, in my youth as guitar amplifiers and PA. I had the PA cathode decoupling caps failed. Foil and electrolyte everywhere. I cleaned it up and replaced the caps, and was ready for the next gig the following week. We were very short of money in those days (mid 60s) and didn't get paid much for playing! ![]() Incidentally I used MS Visio to do the drawing. |
#14 |
Hi Tonyharker, I too have had them go wrong but they were so easy to fix that they would be ready for another gig the next night. It was amazing how many bands started out using those Linear/RSC/ Northwood cage amps there were hundreds of them and many still survive to this day. Other disco lads and bands would bring their amps to me during the week with instructions that they needed them for gigs on a Friday night, much to the consternation of my old man, when he saw the guys coming up his path with long hair and greatcoats! Good days though, but as you say money was tight and you had to make do with whatever parts and spares you could lay your hands on. I recall that my uncle, who was an area manager for DER (TV rentals) used to bring me chassis from old sets that were scrap so I could canibalise them for spares! How times have changed. Its nice to 'keep your hand in' though.
Bill |
