23rd Mar 2008, 6:41 pm | #1 |
Mystery radio
I was given this radio a while ago and havn't a clue what model, manufacturer , anything. The valves were not in the radio when it was given to me.
Could anyone give me a clue? any questions just ask Last edited by samthelemming; 23rd Mar 2008 at 6:51 pm. |
23rd Mar 2008, 6:58 pm | #2 |
Re: Mystery radio
Hi Sam,I think that it is a Windsor or something like that.I don't know if that is the model or the make of it.I remember seeing one at the NVCF a couple of years back and then another one at a BVWS bring and buy fairly recently.I'm sure other members will be able to confirm this or not.
Regards John. |
23rd Mar 2008, 8:12 pm | #3 |
Re: Mystery radio
A further question
The marks left where a tape, a bit stronger than cellotape, was put over the glass onto the bakelite has left marks, any ideas how to get rid of them ? and the white plastic has gone wonky and miss-shaped, is there a way of getting it any better or would looking at making a one out of a thin wooden batton be a good ides ? |
23rd Mar 2008, 8:47 pm | #4 |
Re: Mystery radio
Hi Sam,
The glue from tape can usually be removed with a bit of white spirit or if that fails, methylated spirit. Bear in mind that meths will dissolve a French polish finish - this is obviously won't apply to a bakelite cabinet, but it's best to be careful. An unusual radio - good luck with it! Ian Blackbourn |
23rd Mar 2008, 8:57 pm | #5 |
Re: Mystery radio
Wow! What a lovely radio to restore. I can only guess that perhaps the 6K8/6K7/6Q7/6V6/5Y3 series may fit or perhaps the Mullard red series ECH35 etc. I would certainly derust and finish the chassis with perhaps a metalic paint that I used in my B28/CR100 restorations. I use a few sprays of red oxide primer followed by Halfords metal finish paint. Not too sure what to do with the escucheon, I would be tempted to leave it as it adds its own character, just try to make any obvious repairs to it a bit more invisible.
What a nice project, hope all the expensive hardware like transformers are ok. Absolutely no idea who made that, especially with that dial, could it be a schools radio?
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way! Last edited by Top Cap; 23rd Mar 2008 at 9:03 pm. |
23rd Mar 2008, 9:10 pm | #6 |
Re: Mystery radio
I have looked at the chassis and it would seem someone scratched the valve number into the metal,
I can clearly read PEN46, and im going to have another look at the others now |
23rd Mar 2008, 9:17 pm | #7 | |
Re: Mystery radio
Geof |
23rd Mar 2008, 9:21 pm | #8 |
Re: Mystery radio
Right, I tried my best to decode the scribles and I got,
PEN46 TL41/DD TH41 4UP41 and there was no other scrible for the 5th valve |
23rd Mar 2008, 9:23 pm | #9 | |
Re: Mystery radio
It's however possible that your radio has been designed around military surplus parts. Quite a few small manufacturers did this in the 1940s as huge amounts of WW2 components became available cheaply. PEN46s could well have been used in WW2 radar displays. http://www.r-type.org/exhib/aaa0137.htm Paul |
23rd Mar 2008, 9:25 pm | #10 |
Re: Mystery radio
The PEN46 had a mazda octal base, the central keyway spigot is a bit larger than the usual international octal. I wonder if the other bases are Mazda Octal too, the old SP41's spring to mind. They had 4V filaments like the PEN46 has. Very interesting, perhaps dating this chassis a little earlier than I at first thought.
Les PS Ithink we are all typing at the same time LOL, Yes the other valves you list have 4V heaters.
23rd Mar 2008, 9:27 pm | #11 |
Re: Mystery radio
Yes I allso looked it up and thought "hrmmm" but its theonly really clear one , possibly the surpless idea you had was a good one.
I shall have a go at comparing the bases to a british one |
23rd Mar 2008, 9:32 pm | #12 |
Re: Mystery radio
Any ideas on the rectifier? IW4/350 perhaps?
Nah! wrong Base..what's up with me LOL
23rd Mar 2008, 9:32 pm | #13 |
Re: Mystery radio
Yes definetly a bigger hole in the middle, allthough you wouldn't have known without looking hard
23rd Mar 2008, 9:42 pm | #14 |
Re: Mystery radio
This radio seems to have a similar valve line up
Extract from web:- "Wavebands - SW, MW, LW Valves - TH41, VP41, Pen45DD, UU6 Date - 1945 This is a large set manufactured just after the Second World War. The grey painted chassis is substantial, with separate sub-chassis sections around the waveband switch wafers - it looks more like a piece of military equipment!" |
23rd Mar 2008, 9:52 pm | #15 |
Re: Mystery radio
Yep, Great minds think alike,I just trawled the web and found quite a few radios with similar Mazda lineups like TH41/VP41/HL41DD/PEN45 and all used the UU6. I reckon you will have to do some reverse engineering to obtain a clearer picture, not too bad usually until you get into the front end circuitry.
23rd Mar 2008, 10:06 pm | #16 |
Re: Mystery radio
I have taken the chassis out and the hole with no number has 6 connections to its octale base, if this is any help
23rd Mar 2008, 10:11 pm | #17 |
Re: Mystery radio
Just wondering if the dial used to be a glass affair with all the wavebands painted on it. Maybe it was broken at some time and a makeshift version fitted, I do not think it would have left the factory with that dial.
Now we have the benefits of drawing packages on PC's, it would be fairly easy to make a better version. I would make a temporary one first of all with reference dots on the scales, then use a signal generator to locate various frequency points on the dial, mark them on the temporary ref points, then fill in the figs on the PC for the final printed version. I did a similar job on a B28/CR100 roller dial using in those days a BBC Micro, but it came out very well for what I had to print it out at the time.
23rd Mar 2008, 10:17 pm | #18 |
Re: Mystery radio
I have to admit to tampering with the dial, the original is under the paper, but it is so rusty and the paint is flaky I drew up the paper one myself and it is lightly help on by string as a tempory. I shall post the photo of the original dile in a second when I find it.
24th Mar 2008, 12:11 am | #19 |
Re: Mystery radio
I have had a go at useing photoshop to bring some of the dial back to life, im half way there, have to finish last wavelength and add text
24th Mar 2008, 2:38 pm | #20 |
Re: Mystery radio
After looking very hard, I noticed a name under ALOT! of dirt, I had never seen it before nor herd it, Its says
Money Hicks Ltd, 4684 any ideas? |
