29th Apr 2009, 8:44 am | #61 |
Re: Roberts RT7 - problem
This is my first ever post here, so be gentle with me, and I'm not familiar with this radio, but looking at the circuit diagram above isn't it possible that a break in the track to R30 could be sending the output stage unstable, and all that heat is actually a result of it oscillating violently?
That's my hunch, anyway. I'd be interested to know what the learned company here thinks. Chris |
29th Apr 2009, 10:52 am | #62 |
This repair seems to be going nowhere. We have a radio which doesn't work, pulls down the battery voltage and gets hot. All this suggests that the radio is drawing too much current.
I would suggest:- Investigating the break in the track. If it is indeed a break then bridge it with a piece of flexible wire. Reconnect the speaker. Measure the actual current drawn by the set. Meter set to mA range and connected in series with the battery. One lead to battery positive and the other to the red lead of the set which should be disconnected from the battery. Measure the voltages on all the leads of TR4, 5, 6 and 7. Red lead of meter to chassis. Black lead of meter to the point being tested. Post the results here for analysis.
29th Apr 2009, 1:03 pm | #63 |
I did notice a brown mark on the transformer, which could be an overheating winding causing a shorted turn.
And the solder splutter on the break in the tone correction circuit needs a closer look. This is a classic radio and should be preserved whatever the outcome. I have sent a PM suggesting if it cannot be repaired this way that a modern audio amplifier could be fitted instead. If enthusiastic even make one, in a different thread of course. Geof |
29th Apr 2009, 2:29 pm | #64 |
Thanks all, I'm on it this afternoon, and will take care. The smoke burn on the T2 bracket looked ominous at first sight. The break is bridged, and I'm making notes as I go. Not done yet.
Derek |
29th Apr 2009, 3:49 pm | #65 | |
Geof |
29th Apr 2009, 4:26 pm | #66 |
First, I wanted to see if there was any difference with the section of track repaired.
TR6 & TR7 were re-installed (the 'legs' are quite long, and I was quick with the iron). Battery at 9.95v. Connect and switched on. Able to receive two channels, voices from the speaker, but fading and accompanied by a whistle. Connected the multitester on mA between the positive and red wire, and read 1 . in the 20m range - stable for the duration of the test. Removing the multitester point and re-connecting to the positive on the battery (i.e. switching power off then on) resulted in the voices back, but fading again to nothing. Removing and repeating the process duplicated the result. Switch off, disconnect, battery now 9.8v after approx three minutes connected. Transformers felt cool, TR6 & TR7 warm. Left it for an hour or so. Now to check voltages of TR4,5,6,&7. Tight for space, but managed to get clean contacts on the bottoms of the legs, all components installed. Tester red lead to chassis, black to component. Power on. TR4 Emitter 1.08v; coll. 2.18v; base .77v TR5 Emitter 1.04v; coll. 5.45v; base 1.10v TR6 Emitter 1.9v; coll. 4.87v; base 1.76v TR7 Emitter 3.35v; coll. 2.13v; base 2.10v the figures for TR6&7 were steadily reducing by a tenth of a v per second. Now, the output transformer T2 is getting warm on top (the smoke burnt, melted one), also the TR6 & 7 are getting hotter, so too (though I had not checked this on previous occasions) the capacitor C32 adjacent to TR6 & 7 is also getting warm. The others capacitors remained cool. Switched off and disconnected. Battery now 7.81v. I am wondering if, apart from a short somewhere, one or both the replaced OC81's; TR6 & 7 are in fact being destroyed by this current flow. Their values are no longer similar when checked with the meter before I replaced them. Don't worry, I won't throw it in the skip. I'm ironically getting attached to it. Haven't lifted any capacitors yet. I suspect the output transformer has an internal short - but that is guesswork. Derek |
29th Apr 2009, 5:46 pm | #67 | |
It looks as if the transformer does have a short circuit turn and the OC81 emitter resistance doesn’t look quite right as the emitter voltage has risen meaning they are not conducting properly so may have been damaged. C32 getting warm could be a separate fault, this can be replaced. The squeal is probably just because the voltage is dropping and messing up the radio section, it is encouraging that this stage is working otherwise. A more conventional transformer could be fitted, even a pocket radio type. I have made a sketch from another similar radio, the base bias resistors might have to altered and the feedback resistors from the speaker could be retained instead of how it is shown in my sketch. It does mean a fair bit of modification. I would not turn on the radio anymore until this transformer has been sorted. I wonder if the well known Eagle LT700 Output transformer would work here ? The driver stage looks OK Geof |
29th Apr 2009, 6:55 pm | #68 |
If C32 is getting hot it is obviously faulty. It is quite likely that this component is pulling the battery voltage down, effectively short circuiting it. Remove it and use the ohms range of your meter to check it. A good cap will initially show a low reading which should rise to near infinity as the capacitor charges. A bad cap will show a continuous low reading. Try the meter both ways as the actual polarity of the leads when switched to ohms may vary.
This is not a foolprooof test, as the test voltage will be low and may not "break down" the fault. You could try connecting the capacitor across the battery with you meter set to mA in series. The current should be very low. Judging by your test results there are other faults, but this is an obvious one to start with.
29th Apr 2009, 7:19 pm | #69 |
The base voltages of TR6 and TR7 are way too high. Check R26 and R27 with your meter on ohms range. You'll need to disconnect one end of each resistor before testing it.
29th Apr 2009, 8:01 pm | #70 |
If that transformer is faulty, place an advert for a replacement before you start doing modifications.
I'm very worried about that transformer.... Cheers, Steve P.
29th Apr 2009, 8:04 pm | #71 |
Something doesn't add up here. The service sheet says that TR6 and TR7 collectors should be at 9V, which is the same as the supply voltage. This means that the resistance of the tapped secondary winding of T2 must, by design, be low. Yet the readings taken indicate that about 4 and 7 volts respectively are being dropped in the two halves of the winding. This indicates massive collector current, yet according to post 66 the entire set is only drawing 1 mA. Are you sure this is the correct reading? Some meters have a seperate test lead socket for use when taking current readings.
Similarly the emitter voltages of TR6 and 7 indicate massive current. It's almost as if these transistors were short-circuit from collector to emitter. Are you sure that the new transistors are wired in correctly?
29th Apr 2009, 8:15 pm | #72 |
Agreed, but it still 'partly' works.
The collectors both get their power through the O/P transformer, the bases via R26, R27 and T1. (Trader sheet.) Emitters go to earth. Any solder bridges that shouldn't be there? Cheers, Steve P.
29th Apr 2009, 8:48 pm | #73 |
As you already measured the voltage at the R26/R27 point as 0.2-0.3V then this should be the voltage you see at the base of both TR6 and TR7, the base current should be so small you should see virtually no voltage drop through the trasnformer windings. If it is not then you either have transistors the wrong way round or there is a problem with the driver transformer or the transistors are broken.
The voltage you measured at the potential divider giving the base volatge was correct. As the overheating did not occur with the meter in series with supply this may have had enough resistance to stop the thermal runaway you are getting depending upon how good your ammeter is. Try measuring the resistance of the transformer coils it would then be possible to work out biasing arrangements at it seems the transformer may be faulty causing DC biasing to be incorrect. There are no capacitors that should cause this problem in the output stage. Jeff |
29th Apr 2009, 8:52 pm | #74 | ||
Steve.
29th Apr 2009, 8:59 pm | #75 |
Suppose it's partly going to deck through the transformer?
Cheers, Steve P.
29th Apr 2009, 9:01 pm | #76 |
I'm not sure I would know if there were solder bridges that shouldn't be there Steve, but I cannot see anything under the board that looks out of place or 'extra', though if it had been done well, maybe I would not notice.
As regards the meter readings on current, yes - there is more than one connecting socket on the meter for the red lead, and it is possible I have used the wrong one. I switched round to the 20m range in the 'A' quadrant, and got 1 . with the red lead in the V/ohms/mA socket. Now I've just been back to the bench and carried out another quick check with power on, and got 0.03 with the red lead in the 10ADC socket, and switched round to the single 10A range. Told you I didn't know what I was doing! Got to be led by the hand everywhere . . . OK, looks like I'm on a transformer hunt. Meanwhile, I'll lift the C32 capacitor and see what readings I get. Should I be successful in getting a replacement T2 I can plan to move on from there. Lots of interest in this thread and I must thank all involved very much for the advice given. Duff forecast for tomorrow, so might get started on pulling the T2 from the board, and perhaps a visit to Maplin. Don't think they'll have what I want, but never been before. Thanks all round gents, I'm still listening. Derek Not a prime example, but here it is: Last edited by stonehopper; 29th Apr 2009 at 9:17 pm. |
29th Apr 2009, 9:03 pm | #77 | |
Steve. If that were the case the voltage would be high even with TR6 and TR7 out of circuit. Yet apparently with these transistors out the voltage is OK.
29th Apr 2009, 9:12 pm | #78 | |
If you go back to post No.20 and check out the thumbnail furthest right, you will see over the top of the smoke burnt bracket, the tips of bare metal from where I made that continuity test to chassis. |
29th Apr 2009, 9:25 pm | #79 | |||
I think you're being too hasty in suspecting the transformer. Transformers can overheat and still remain perfectly servicable. I'd concentrate on R26, R27 and C32.
29th Apr 2009, 9:45 pm | #80 | |
Derek |
