Reply
Old 9th Feb 2010, 2:06 pm   #141
ahjohn002
Default Re: The "Sussex" Homebrew Valve Tester.
Hi All,
Glad to know that this thread is alive and well.
John
ahjohn002 is offline   Reply With Quote
Old 9th Feb 2010, 7:15 pm   #142
David G4EBT
David G4EBT's Avatar
Although I'm not building the Sussex, I am using a digital panel meter for another project I'm building, which looks identical to those used in the Sussex. The meter arrived today from China, and warns that you must not use a common earth for the measured power and the power supply to the meter.
To quote verbatim:
"Warning: The working power and the measured power can't use one power system together. When LCD meter uses DC working power, must use the isolated power suplly, can't be sharing the power for meter. Wworking power and meter power can't use common ground wire, otherwise meter will be burnt. The meter power must be 9 - 13.5V, if greater than, then be burn".
So there you go then - "no crash and burn = no common ground"!
Oddly, it also says "meter power AC/DC: No +/- differ".
I can understand that on AC, but it seems odd that it infers that even on DC, the power supply to the meter isn't sensitive to polarity. I haven't tried to pwer it up yet - the colour code of the wire doesn't give much of a clue - brown and red is meter power, orange and yellow is measured power.
The one I've bought is scaled 0 - 199.9V DC. (It's for a zenner diode tester project).
I know it's a bit off-topic from the Sussex, and haven't studied the circuit to see what the power supply arrangments are to the meters, but they obviously work OK as Mike has proven.
I guess these Far East meters are fairly generic - the type I've obtained is a "D69" - they come in a range of scales, up to 500V AC or DC, and up to 2 Amps. The last one I bought was a 500V one for the Capacitor Reformer project which featured in Bygones and the BVWS Bull.
I did squirt more than 500V into it, and - as our inscrutible friends advised, sure enough, it did "burn", so I sent for another and was more careful with that one!
Regards, and best of luck to the "Sussex Legionaires"!
David,
G4EBT
David G4EBT is offline   Reply With Quote
Old 9th Feb 2010, 7:28 pm   #143
swordholder
David,
Thanks for that I did realise that, and ED has 3 seperate 6V windings on his transformer. I had previously used one 6V winding on the mains transformer with an extra 2 x 6V transformer.
Regards
Mike
swordholder is offline   Reply With Quote
Old 9th Feb 2010, 8:02 pm   #144
David G4EBT
Ye, I guessed you'd have it sorted Mike - I thought it was worth a mention in case anyone went off on a frolic and did their own thing, or wished to use the meters in some other project, as I'm doing. In my case, two separate PP3 batteries will do the trick - one for the project power supply, the other for the meter.
I see that the Sussex thread has now been viewed 8415 times, and had 144 postings with this one! It's go to be top of the pops - way out in front as a home-brew project. (A bit like winning "Pop Idol" Mike, without the dosh and public acclaim to go with it - except of course from forum members
Regards,
David,
G4EBT
Last edited by Dave Moll; 9th Feb 2010 at 9:34 pm. Reason: unnecessary quote removed
Old 10th Feb 2010, 12:16 am   #145
M0XNA Neil
I'm building the 'Sussex in a suitcase' with bits and pieces I have lying around in the garage. I have built the chassis to sit within an old Maplin black DJ suitcase with room at the side of the chassis for cable storage. Instead of using the panel meters, I am using four cheap Maplin yellow DVMs I have. They will be fixed to the inside of the lid and connected via banana fly leads to the VT panel. By this means I can also use the four DVMs for cathode current balancing in valve audio amps. I will post some photos soon.
Neil.
An engineer makes for a penny what a scientist makes for a pound!
M0XNA Neil is offline   Reply With Quote
Old 10th Feb 2010, 12:27 am   #146
David G4EBT
Good to hear your progress Neil.
re the Maplin yellow perils, yes, they're cheap as chips - sometimes on offer at two for a fiver. I've got them scattered all over the place, bought on impulse - in the car boots, garage, shed etc.
So cheap that they're cheaper than an analogue movement.
Neat idea to use the four set to the desired range and fixed into the lid.
Best of luck with your Sussex!
It will be interesting in due course to see the library of pictures of all the variations on a theme. The PCBs and custom transformer will be a boon to most constructors, I'm sure.
Regards,
David,
G4EBT
Last edited by Dave Moll; 10th Feb 2010 at 3:52 pm. Reason: PLEASE NOTE THAT IT IS NOT NECESSARY TO QUOTE THE ENTIRETY OF THE PRECEDING POST
Old 10th Feb 2010, 7:55 pm   #147
G8UWM-MildMartin
I now have the PCBs.
They are etched only, and as per Mike's original design (no HT bridge mod.), on 1.6mm fibreglass, undrilled, no resist, no silk screen, etc.
I'm asking £10 including UK post, and promise to pass on the profit from each sale to Mike, regardless of whether all 49 (since I'm keeping one) eventually sell.
ID:	32489   Click image for larger version
ID:	32490   Click image for larger version
ID:	32491   Click image for larger version
G8UWM-MildMartin is online now   Reply With Quote
Old 11th Feb 2010, 6:26 pm   #148
swordholder
Hi Guys
Attached is a photo of my modified Sussex after fitting Ed's transformer.
Note the addition of the heater voltage selector switch.
The button between the meters is the "Gas" test button mentioned in a previous post.
The printed area of the front panel is 297 x 60mm and can be printed out on standard paper. I used a 2mm clear perspex cover, a lot of firms on E Bay sell A4 size and will cut for no extra cost.
Now that the PCB is available, and Ed's transformer is imminent, it's time to go.
Regards
Mike
Name:	Modified Sussex Front Panel.jpg
Old 11th Feb 2010, 10:03 pm   #149
Ed_Dinning
Hi David, I think it may have been mentioned in an earlier thread. There is a bridge rectifier in the meter, this sorts out the polarity of the supply but is part of the problem if you try to measure the "supply" supply.
Ed
Ed_Dinning is online now   Reply With Quote
Old 13th Feb 2010, 9:54 pm   #150
Ed_Dinning
Hi Gents, transformers will shortly be ready and I will be sending them out over the next 10 days.
They are wax impregnated and are fitted with stainless brackets for use as feet (drill as you require.
They will be dispatched with full connection details.
I will PM the recipients as they are dispatched.
Ed
Old 14th Feb 2010, 1:12 am   #151
Guitarist28
Guitarist28's Avatar
Hi Ed
Excellent news and well done
Regards
Rob
Guitarist28 is offline   Reply With Quote
Old 15th Feb 2010, 12:20 am   #152
Top Cap
Top Cap's Avatar
Although still awaiting the arrival of the PCB, I decided to try and work out how it will interface with the circuit diagram. I decided to give each terminal node an identifier which may (or may not) help me put together my version of the Sussex VT. The info I have put together may be of some use to anyone else building the same and I have put it here:-
PCB with idents:-
http://homepage.ntlworld.com/lez/Sus...%20circuit.JPG
Overall circuit:-
http://homepage.ntlworld.com/lez/Sus...nstruction.JPG
Please note
1) I have not added the bridge rectifier modification yet.
2) The Heater select switch has vacant positions 2 and 3, this is for adding
1.4 and 2V DC supplies later, for directly heated battery valves.
3) I am hoping to be able to switch just one side of the heaters to allow me more switch option positions later.
4) I have yet to decide on D1 and D2 inputs for the Pin selector switches.
Presumably some form of pre-set current limiting would be required here.
There are two R23's on the original board layout and I have re-labelled it as R27. I also suspect that the LED's (except for LED1 on the PCB) are shown the wrong way round?
As the title of one of the drawings suggests, it is work under construction and hopefully you may find some errors that I have missed.
I am going to wait until the tester is built before fitting any ferrite beads etc., I was going to fit chokes until I realised ... the heater current .. doh!
It might be a good idea though to put one in at the Top Cap Grid connection.
The only other change I have made is to fit backstop diodes across the three relay coils, not shown yet across RL1.
Les
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way!
Top Cap is offline   Reply With Quote
Old 15th Feb 2010, 12:57 am   #153
Andymic
Les,
That is very useful indeed.
Thank you
Andy
Andymic is offline   Reply With Quote
Old 15th Feb 2010, 3:41 am   #154
Andymic
Mike,
Am I correct in assuming this only applies to the dc meters and not the ac?
Andy
Old 15th Feb 2010, 3:55 am   #155
Andymic
BOM updated... http://spreadsheets.google.com/ccc?k...pfMlE&hl=en_GB
Mike,
Can you give me the part number of the 2p6w switch you used please
Andy
I'm off to bed. It's late !!!
Old 15th Feb 2010, 8:44 am   #156
swordholder
Andy,
The 3 x 6v windings supply each of the meters (both DC & AC)
Each meter has its own winding.
The switch for the heater is Rapid Pt No 79-0221
Mike
Old 15th Feb 2010, 8:55 am   #157
swordholder
Les,
Very well done, I dont have any CAD programmes here.
Regarding your connections D1 & D2, I purposely didn't put any rectifier test on the tester.
All the AVO testers appear to run the rectifiers at around 100v.After discussing this with a friend who repairs Hi End audio for a living, he says he has had many current production rectifiers which test perfectly OK on an AVO, yet fail (arc over) when you put 350 - 400v on them. So unless you give them a "good work out" it appears a low voltage test is pretty meaningless.
What are your (and others) thoughts.
It's good others are throwing their ideas into the pot.
Regards
Mike
Old 15th Feb 2010, 9:13 am   #158
Andymic
Mike,
Yes, sorry I had a late one last night. I've taken another look at the diagram and there are indeed 3 separate taps for the meters.
Incidently, only the two DC meters had the warning David mentioned, the AC meter did not (which is why I asked).
Andy
Old 15th Feb 2010, 10:51 am   #159
Guitarist28
Hi All,
I'm having a Homer Simpson moment here so please excuse my ignorance - what is the value of the pot(?) that is the grid voltage control?
Thanks
Rob
Old 15th Feb 2010, 12:01 pm   #160
swordholder
Rob,
I used a 30K (simply because I had one) but not critical. Rapid do a 50K which should be OK
Mike
Reply
