23rd Jul 2017, 2:51 pm | #1 |
Advice on replacing IF transformer
Hi, I am new to radios and am trying to restart a Stewart Warner 62T36. The first IF transformer is bad (455kHz, part number 502102 or 16-6658). Does anyone know if these can be replaced? Where would I buy one? Thanks!! Henry
23rd Jul 2017, 3:09 pm | #2 |
Re: Advice on replacing IF transformer
What is the fault with the transformer? Unlike European sets, American radios of this era are notorious for faults in the padding capacitors inside the transformers.
23rd Jul 2017, 3:22 pm | #3 |
According to the schematic the IF transformer's tuning capacitors are of the variable type, need more info regarding the defect:
http://www.nostalgiaair.org/pagesbym...7/M0020757.pdf Lawrence. |
23rd Jul 2017, 5:14 pm | #4 |
Hi, from what I can gather on this item the primary and secondary should read 20R. The primary is 20R but the secondary is infinity. There must be a break.
23rd Jul 2017, 5:20 pm | #5 |
Actually the primary is 22.9R and secondary is broke. Here is a picture of the little beast.
23rd Jul 2017, 6:47 pm | #6 |
I found this:-
http://www.antiqueradios.com/forums/...c.php?t=165802 I'll give it a try, I just need to pick-up a 100K resistor. |
23rd Jul 2017, 6:54 pm | #7 |
That type of IF transformer seldom gave any problem, unless the fine wire going to the coils has been disturbed or it was damaged by someone or an insect getting inside. The transformers come apart rather easily for inspection. As stated before, more information is needed.
23rd Jul 2017, 8:58 pm | #8 |
It is strange that it is broken. As far as I can tell the two fine wires entering the coil are fine, and the coil is encased in wax.
24th Jul 2017, 9:45 am | #9 |
I thought I had replied but it seems to have gone. Here I go again.
I have used a mini single tuned transformer from a transistor set, connected directly on the valve base. Top coupling to the primary was by a home made capacitor of about 5pF. Rewinding of the faulty coil should be possible, I do not know what the effect would be of replacing the wave wound coil with a solenoid winding which would be easier to do. |
24th Jul 2017, 12:03 pm | #10 |
A pile winding with the same footprint as the original wave one would probably be better.
Melt the wax off with carefully directed hot air so you can reuse it to coat the new winding.
24th Jul 2017, 1:44 pm | #11 |
Wow, way too complicated for a newbie like me, I'm not sure how to wind the wire - that must take hours?!? I'll try the cap and resistor first, I can tuck it up in the can so as no one knows.
24th Jul 2017, 6:00 pm | #12 |
The cap and resistor bodge should work OK but you may lose some selectivity (set not so good at rejecting close in unwanted signals).
24th Jul 2017, 7:52 pm | #13 | |
Give it some thought and a try. There is nothing quite like hearing a station from a radio built from scratch....and you'll learn a lot by doing it.
24th Jul 2017, 9:05 pm | #14 |
I have not unwound an IF transformer but doubt if there are many more than 100 turns. I have wound a solenoid for a slave clock, using 30,000 turns this did take a while since the wire was very thin and I was worried about breaking it. This was done using an AVO coil winder without the traverse working.
I have thought of a way to make a wave winder attachment but I have other priorities at present and I am not too good at construction but I am quite a good bodger. |
28th Jul 2017, 2:03 pm | #15 |
I.F. transformers do sometimes appear on EBAY but the only ones at the moment are out of a 19 Set, they would work but if you wait you might get something closer to the original
29th Jul 2017, 4:44 pm | #16 |
I have an IF transformer that would be a direct replacement for the one needed, even though it's out of a different make of radio. I'll have to check with the Post Office to see what's all involved in sending it to you.
31st Jul 2017, 4:47 pm | #17 |
I've seen the circuit used in the lower priced 5 tube radios in the US, but in the 2nd IF circuit. They really weren't bad in selectivity and sensitivity, but they did lack good AVC/AGC action.
3rd Aug 2017, 5:12 pm | #18 |
I inquired about the cost of shipping and Customs payment at the Post Office and was quoted around $22 USD. I thought, that was a lot of money to post an item that is in a small package and weighs less than a pound!
