22nd Jul 2017, 1:14 pm | #1 |
Sobell Bakelite radio enquiry.
Hi everyone I'm new to this so some advice please. I've just bought a very nice Sobell bakelite radio but I have no idea of age, model number or if it's rare. I can't see anything online about it. I'm trying to upload a picture but I have no idea how to lower the resolution to send. Any advice would be much appreciated. . Thanks Phil.
22nd Jul 2017, 1:16 pm | #2 |
Re: Bakelite radio enquiry
Hello and welcome to the forums. A model name or number for your radio will help.
So long as you don't mind waiting while they upload, you can upload oversized images. The forum software will resize them for you.
22nd Jul 2017, 1:31 pm | #3 |
Re: Sobell Bakelite radio enquiry.
Thanks for that can't seem to find a model number anywhere. I'll try to upload a picture.
22nd Jul 2017, 2:58 pm | #4 |
22nd Jul 2017, 4:23 pm | #5 |
It does seem to be quite an unusual beast - no obvious sources of data, but there are also photos around of a Sobell 599 which appears to be the same thing in a wooden cabinet.
Its appearance says 1948 to me, give or take a year or two. Perhaps the chassis is shared with other models. Does it resemble the 516 internally? http://www.radiomuseum.org/r/sobell_516.html |
22nd Jul 2017, 7:01 pm | #6 |
Thanks Paul it does look very similar internally. Do they keep their value, because I was thinking about replacing the internals with a modern Bluetooth system, or is this sacrilege? Thanks again Phil
22nd Jul 2017, 11:03 pm | #7 |
At the end of the day it is your choice but I would say definitely don't do that. Get the radio working first, there are lots of guides for starting out on here and other websites and if you get stuck the people here are more than happy to help you out. You will enjoy it I'm sure. Then if you still want a Bluetooth speaker you need to find a way to input into the radio, again asking here would probably yield results. Finally buy a Bluetooth receiver and plug it in. The radio will be original and the process will be reversible in the future. It will probably sound a lot better too! The sense of achievement after fixing a radio is well worth the time
25th Jul 2017, 12:38 am | #8 |
Thanks for your advice. I think I'll have a go at getting it working. Where do I start I presume the valves will need to be replaced. From there I haven't a Scooby? Any advice will be very much appreciated. Phil.
25th Jul 2017, 8:23 am | #9 |
25th Jul 2017, 9:55 am | #10 |
Unlikely that you will need to replace all the valves, usually they will be fine.
The output valve is the hardest worked one. A few capacitors is probably all it needs and a bit of TLC. |
25th Jul 2017, 12:55 pm | #11 |
Valves are usually ok like Sam says, it's capacitors which are the problem. The link provided by Station X is where I started a few months ago, that and this forum have helped me greatly. It may seem daunting at first but it's really not too bad. Cut out the old capacitor and put in a new one of the same value, just read up on the ones you should replace. Good luck
28th Jul 2017, 12:29 pm | #12 |
I had an AC only 516 chassis in the bakelite case. The valve type numbers are a big clue.
If it is AC-DC you will have to be very careful not to touch anything unless the mains plug is out! |
28th Jul 2017, 3:22 pm | #13 |
Two other variations of the 516 AC only model. The transformer can be seen in the back right hand corner. If yours doesn't have this then it is a different AC-DC model such as the 599U mentioned above.
The one with the semicircle dial was still in it's box when I got it about 37 years ago and has only been powered up a couple of times since. Unfortunately it had been somewhere damp and the box just disintegrated. I think all had a Pick Up input and you can feed your MP3 player or DAB radio into that, once you have the radio working of course. Last edited by See_Mos; 28th Jul 2017 at 3:38 pm. |
30th Jul 2017, 9:21 am | #14 |
Thanks all I'll have a look sometime today. If you see a big mushroom cloud over the West Midlands area then you'll know... It didn't work. Phil.
30th Jul 2017, 9:40 pm | #15 |
Did you get a chance to take a look? I didn't hear about any mushroom clouds.
