22nd Jul 2017, 5:32 pm | #21 |
Re: Small Sidecutter Recommendation
A vote for Lindstrom here, too- if you're keen and your wallet will stretch to it! I have often heard CK praised and I do use them day-to-day but in the past I have had the jaws on CK side-cutters fracture and break off just trimming standard copper tails on PCBs- poor treatment process. I suspect that they may be a victim of "Germanism"- the acqusition of a renowned brand by a multi-national corporation whose bean-counters out-source and steadily erode production costs but continue to ask a premium price solely on the basis of the brand.
22nd Jul 2017, 5:47 pm | #22 |
Lindstrom gets my thumbs up - had a pair (green arms) for well over 30 years and still as good as ever - fantastic!
Now where on earth did I remove that from? Last edited by af024; 22nd Jul 2017 at 5:48 pm. Reason: sp |
25th Jul 2017, 3:46 pm | #23 |
I seem to recall that my Lindstrom full flush oblique cutters, which are still going strong after 40 years, are rated at 1mm un-tinned copper wire. This sprang to mind today whilst repairing a Chinese made SMPS that had corroded (rusty) resistor leads and board interconnects. Many components from The Middle Kingdom have plated steel leads.
Just a thought. One of my Lindstroms has a notch in the cutter blades from when it was borrowed without permission and someone (incidentally, in China...) cut a locking wire on a screw with them. BC |
26th Jul 2017, 8:50 am | #24 |
Thanks for all the posts, its a big help. I may opt for CK, purely on price, though when Im more flush I will probably get some Lindstroms.
I instantly recognised the pictures of Erem cutters that were posted, as my other half has some for modelling work and I occasionally pinch them! They are great and very small for fitting into hard to reach areas |
26th Jul 2017, 9:30 am | #25 |
I have a CK wire stripper which seems very well made and does the job perfectly. I haven't had it for long but it seems like a good quality bit of kit. I need to look at getting myself some new sidecutters my cheap pair got ruined just cutting a few capacitors.
26th Jul 2017, 10:02 am | #26 |
Though these are really cheap, I've used them for a few years now for snipping component wires:
http://cpc.farnell.com/duratool/d030...s-5/dp/TL08617 No good for hard steel, of course, but for anything like that I use my Leatherman - though seeming expensive they have never failed me. http://www.leatherman.co.uk/wave/10....lor=41#start=1
Mike. |
1st Aug 2017, 1:34 am | #27 | |
Re: Small Sidecutter Reccommendation
They cost be 99p per piece from China via eBay. |
