Old 24th Jul 2017, 5:14 am   #41
TonyDuell
Default Re: Build your own? A discussion.
Another company that used to expect their instruments to be repaired was HP (in the good old days...). I've got HP test gear with an extender board for all the plug-in PCBs stored inside, for example.
Now as to miniaturisation and neatness... There are times that miniaturisation matters for technical reasons (stray capacitance being the obvious example). And plenty of times when it doesn't. I don't care if my special-purpose meter, used in my workshop, is in a case the size of a Fluke 70 series or in a 3U rack box. The latter might be easier to use as the controls are likely to be more widely spaced. I don't even care for things I have to carry around. If I am carrying a reasonable toolkit, then whether the special test set is in a Fluke-sized case or a larger plastic box from RS doesn't make much difference to be honest. The idea that everything has to be as small as possible is in most cases simply 'fashion' which has no place in my workshop.
As for 'well machined', firstly some of us do have reasonable workshops and can turn out (pun totally intented!) spacers, knobs, brackets, milled rectangular holes in panels, etc. And secondly, again, does it matter? A display window that's not a perfect rectangle, or controls labelled with a 'Sharpie' will not affect the accuracy of the results.
TonyDuell is offline
Old 24th Jul 2017, 10:15 am   #42
MrBungle
MrBungle's Avatar
A lot of the "minaturised" kit is actually easier to work on. The killer is poor designs, particularly as promoted by Tektronix. So you want to replace the HV module? See you at 3AM covered in blood and swearing. One of the nicest things I've ever worked on was a reasonably new digital HP 54601 scope. There was a burned tant on the main board. It was SMD, easy to get to and replace!
My own creations think about access first because I *know* I'm going to have to go in there and change something at some point.
MrBungle is offline
Old 24th Jul 2017, 11:40 am   #43
Skywave
Thumbs up Re: Build your own? A discussion.
Agreed: my sentiments exactly. And that's why when I have designed, built and tested something which I've made for myself, I always make sure I have produced accurate documentation.
Al.
Skywave is offline
Old 24th Jul 2017, 11:43 am   #44
Skywave
Originally Posted by SiriusHardware View Post
The main reason to build anything now is because nobody else actually makes one.
Indeed: my opening post stated:
Originally Posted by Skywave View Post
In one of M.G. Scroggie's books - dating from the 1950's - he makes the observation that sometimes it is necessary for the hobbyist / experimenter to design and build his own item of test equipment when his need cannot be met from what is commercially available.
Al.
Skywave is offline
Old 27th Jul 2017, 10:00 pm   #45
Graham G3ZVT
Graham G3ZVT's Avatar
I've told her that, but the XYL still won't let me put this thermostat in the hall.
https://www.vintage-radio.net/forum/...1&d=1501189044
Graham.
G3ZVT
Graham G3ZVT is offline
Old 27th Jul 2017, 10:41 pm   #46
Radio Wrangler
Radio Wrangler's Avatar
Ah, I understand.
It simply isn't a recognisable expensive enough brand.
Radio Wrangler is offline
Old 27th Jul 2017, 11:04 pm   #47
JohnBHanson
You should have branded it with your name - then it can be shown off to all visitors with pride (hopefully)
JohnBHanson is offline
Old 27th Jul 2017, 11:45 pm   #48
Biggles
I have a home made nixie tube clock in the living room which often provides interest to visitors as it is "unique". My wife tolerates it's presence but on occasion something gets placed in front of it, obscuring the display. Borderline. I don't think she appreciates odd home made electronic gadgets in the house. For some reason she doesn't mind an Airfix model of a Catalina flying boat on display that I made a while ago when I was off work. Odd. Very odd.
Alan.
Biggles is offline
Old 28th Jul 2017, 7:56 pm   #49
G8HQP Dave
Someone married to Biggles could hardly object to a flying boat! Do Ginger and Algy drop in for a drink from time to time?
G8HQP Dave is offline
Old 28th Jul 2017, 9:14 pm   #50
Biggles
I wish, Dave. I could have some interesting conversations with them! The name all stems from when I was in my teens and wore a genuine WWII flying jacket, which I still have incidentally. My Dad gave it to me when I started riding motorbikes. The nickname stuck. He was in the RAF for a while. Then I joined the Civil Aviation Authority. And that was that. I have a good photo with me wearing it. I have been tempted to use it as my avatar.
Alan.
Biggles is offline
Old 28th Jul 2017, 11:55 pm   #51
AC/HL
AC/HL's Avatar
Give in! Which reminds me, you can't get wire coat hangers these days, plastic doesn't look right!
AC/HL is offline
Old 29th Jul 2017, 6:43 am   #52
Radio Wrangler
Wire coat hangers aren't available because they're no longer needed - most cars now have radio aerials embedded in windows.
