Old 16th Jul 2017, 2:36 pm   #1
Wishiknewmore
Default Those heavy yellow 110v site transformers
Hello
I have managed to collect three French radios which are all 110v but as yet I have not made enough effort to find a suitable power supply, then I thought about those heavy yellow ones for power tools!
But I have some recollection of reading that they were not suitable, but I can't remember why or where I read it?
Views? Thoughts?
Philip
Wishiknewmore is online now
Old 16th Jul 2017, 2:46 pm   #2
Boater Sam
Default Re: Those heavy yellow 110v site transformers
They are centre tapped earthed secondaries. They will get hot if run for a long while but otherwise I can't see why they would not do. The regulation may be a bit scatty though.
Boater Sam is online now
Old 16th Jul 2017, 2:49 pm   #3
julie_m
The 110V power tool transformers have a centre-tapped secondary (55-0-55V) so might not work so well with any appliance that relies on one side of the mains being much closer to Earth than the other. However, this is highly unlikely to be an issue with a domestic radio set. Ionisation flame sensors and some kinds of touch switch would be affected, though!
julie_m is offline
Old 16th Jul 2017, 4:49 pm   #4
G6Tanuki
G6Tanuki's Avatar
I've used these extensively; as others have mentioned there's a centre-tap on the secondary which is either tied to the supply-earth or brought out to a separate terminal allowing the user to decide-what-to-do.
I untie the centre-tap and present it as an external connection so I can choose what to do with it [generally leave it floating and instead tie one of the transformer-ends to ground]
They're generally well-built, happy to handle the rough-and-ready power-factor-distortion of inductive loads like the motors in power-tools.
G6Tanuki is offline
Old 16th Jul 2017, 4:50 pm   #5
TonyDuell
Most of those power-tool transformers are potted in resin inside. So while in principle you could disconnect the centre tap from mains earth and say earth one side of the secondary, this would probably result in the core being 55V AC wrt. earth (as it was originally earthed to the centre tap). You can't get to the individual connections to separate the winding tap from the core connection due to the potting.
The transformer I have (for power tools, mainly) claims to be rated at 3kVA for 20 minutes, then let it cool for the same time (or something like that). What is stated nowhere that I can find is the maximum continuous load. I assume it's non-zero, since on building sites, etc, the transformers are left plugged into the mains all day and the load
(power tool) is switched and AFAIK the transformers don't overheat like that. So there's
enough copper and iron to withstand mains input continuously.
Given they are rated at 3kVA and most radios are under 100VA I would be surprised if the transformer couldn't run it continuously.
TonyDuell is online now
Old 16th Jul 2017, 5:12 pm   #6
I have never known or heard of one blowing up, worst case is either quite smelly and hot or the thermal fuse (if fitted) trips (most seem to have self resetting ones). We have one at work to power USA destined equipment it is powered on 24/7 and usually for a soak test left with a few hundred watts of load for days. It doesn't even get warm.
Old 16th Jul 2017, 5:54 pm   #7
OscarFoxtrot
OscarFoxtrot's Avatar
Specs vary, but I've found for separate 3kVA transformers:
Continuous load: 2/3rds of rated.
Maximum lighting load: 1000 W
Continuous rating: 1500VA, intermittent rating: 3000VA
You can get smaller ones (but they're not necessarily cheaper)
http://www.screwfix.com/p/portable-t...p-1-2kva/30758
600VA continuous, and one of the reviews described it as "a little camp"
OscarFoxtrot is offline
Old 16th Jul 2017, 7:31 pm   #8
Wishiknewmore
Thank you everyone
So in summary, it will be adequate for me to use as a power supply to get these things working.
That gives me a start, as I know I can borrow one from my brother in law on a long term basis
However it does remove one of my excuses for tackling them!
Thanks again
Philip
Old 16th Jul 2017, 8:10 pm   #9
Andrew B
Andrew B's Avatar
Before it became the "norm" to pot these transformers, it was easy to strip off the secondary winding and rewind it to needs.
worried about the electrons entering the circuit and the smoke leaving
Andrew
Andrew B is offline
Old 17th Jul 2017, 9:51 am   #10
kellys_eye
I think I'd rather stump up for a dedicated 230/115 transformer and case-it-up than have such a 'lump' somewhere it could take a chunk out of my shin!
A toroidal rated at 100W (or so) costs........ what?
kellys_eye is offline
Old 17th Jul 2017, 6:02 pm   #11
Herald1360
Herald1360's Avatar
If you already have a 1:1 iso TX get a cheap auto TX of the right ratio and rating to use between the mains and the iso TX primary.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 17th Jul 2017, 6:38 pm   #12
TonyDuell
I found it surprisingly difficult to get a small isolating transformer. I was looking for something with a mains primary and 2 half-mains secondaries (so 230V in, 2 off 115V out), the idea being I could connect the secondaries in parallel to run 115V stuff or in series to run 230V stuff. If anyone knows an inexpensive-ish source of such a transrormer (torroidal or conventional core) let us know.
RS do/did a nice 200VA transformer with a primary tapped 0-230-415V and 2 off 55-0-55 secondaries, but it was not cheap. I do have one somewhere I must get round to boxing it up.
Old 17th Jul 2017, 6:51 pm   #13
G6Tanuki
G6Tanuki's Avatar
Search for "Panel Transformer".
Industrial process-control/instrument-panels are stuffed full of situations where you have something crazy like a 415V 3-phase supply and need 110V single-phase, or you have single-phase 110V-with-one-side-grounded and need 220V 2-phase floating...
And the "Panel transformer" world is full of interesting solutions!
In the past I've stacked a pair of 240-to-415V transformers and wired the secondaries in series so I can full-wave-rectify the result and get nearly a Kilovolt at a healthy amp or so to power one of my HF/low-VHF RF linear-amplifiers.
G6Tanuki is offline
Old 17th Jul 2017, 7:52 pm   #14
55-0-55 (more like 55 and 55) transformers are readily available, two should fit most needs.
Old 18th Jul 2017, 9:58 am   #15
OscarFoxtrot
Nothing to stop you putting it somewhere inconspicuous and wiring in a 110V mains circuit to suitable sockets around the house -- MK make USA 110V sockets in UK faceplate style, or you could use 2A round pin if not used for other purposes already.
Old 18th Jul 2017, 10:27 am   #16
mole42uk
mole42uk's Avatar
Just to keep the record straight, they are not all 3kVA - I have one in the workshop which is only 750VA. It is still in a yellow box with a handle on top, but much lighter to carry!
Richard
Index:
mole42uk is offline
Old 22nd Jul 2017, 12:51 am   #17
Andrew B
Andrew B's Avatar
Since the advent of "disposable" microwave ovens, even doing that has become an obsolete art. Apart from that 813's are happier with 2KV
Andrew
Andrew B is offline
Old 22nd Jul 2017, 11:32 am   #18
short wave
Hi Philip is the French system 50Hz or 60 Hz, if your radios have a transformer fitted it might get warm?.If it is built like an AA5 it should be ok.
short wave is offline
Old 22nd Jul 2017, 12:21 pm   #19
McMurdo
McMurdo's Avatar
AS a rule the plastic bodied ones tend to be potted and the metal ones aren't. None of ours are encapsulated and all can have the centre tap disconnected if necessary. One of ours in the welding shop is (despite my objections) left switched on 24/7 and it doesn't get even warm. Modern ones usually have thermal breakers and the older ones internal fuses. They're a good general purpose workhorse and more than a match for any old radio!
Kevin
McMurdo is offline
Old 22nd Jul 2017, 3:54 pm   #20
I had a close look at the works one, it has a resetable thermal trip (those clear 'rubber' button things).
