15th Jul 2017, 3:12 pm | #1 |
Resistor confusion
what does the team think the value of this is please? There's 2 on the board, this one reads 270k, t'other open
many thanks |
15th Jul 2017, 3:15 pm | #2 |
Re: Resistor confusion
Brown, black, black, yellow with a brown tolerance band . I'd say it was 1M 1%. Did you measure the 270k with it in circuit?
Keith |
15th Jul 2017, 3:18 pm | #3 |
Yep, I'd read that as 1M 1%
15th Jul 2017, 3:20 pm | #4 |
Ditto.
Lawrence. |
15th Jul 2017, 3:28 pm | #5 |
thanks guys. Keith, yes 270k in circuit
15th Jul 2017, 3:54 pm | #6 |
Looks like there's a parallel circuit causing the lower resistance. Try lifting one end and re-measuring.
Keith |
15th Jul 2017, 4:38 pm | #7 |
Thanks Keith. I admit that value had me foxed, I still read resistors in 'old money' !
15th Jul 2017, 5:24 pm | #8 |
This is a handy site for us old'uns. Just select the number of bands. The tolerance band is the wider spaced one. Several other conversions as well.
https://www.digikey.co.uk/en/resourc...or-code-4-band |
15th Jul 2017, 5:41 pm | #9 |
Resistors (through hole ones) are now so small and have so many bands I have to use a magnifying glass to read them.
And even then there can be ambiguity. Brown black black brown brown can be 1k (brown black black brown) 1% read one way, and 110 ohms (brown brown black black) 1% read the other. Although the brown 1% tolerance band ought to be wider than the value colours, it is often not clear. So after using a magnifying glass I then use a DVM to measure the darned thing to eliminate possibility of error. And don't get me started on the cryptic labeling of surface mount parts.... Craig |
15th Jul 2017, 6:26 pm | #10 |
Recently bought some of these - 1MOhm. The way I see modern ones is an extra number band with standard multiplier so 100 with 4 zeros - 1MOhm.
My 10MOhm are brown, brown and black with green multiplier - 100 and 00000. My 10 kOhm are brown, black and black with red muliplier - 100 and 00 That way it just seems like the old method with an extra band. I do agree that the banding is not easy to read though |
15th Jul 2017, 7:40 pm | #11 |
15th Jul 2017, 8:05 pm | #12 |
Hi.
For most of used to the old 4-band system it certainly can cause confusion trying to interpret the 5-band and 6-band codes. With the old 4-band system it was so easy to recognise values quickly. We got used to the third band multiplier, black (tens of Ohms), brown (hundreds of Ohms), red (thousands of Ohms), orange (tens of thousands of Ohms) etc. It definitely takes longer to decide the correct value with the 5 and 6-band codes. Regards Symon. |
16th Jul 2017, 7:03 pm | #13 |
17th Jul 2017, 1:02 pm | #14 |
It gets even more interesting with proper E96 1% or E48 2% resistors when the second two bands are totally "unexpected" colours. 29.8 ohms would be red white grey gold brown for instance, though at least that would be a nonsense read backwards, unlike say 120R vs 10k.
....__________ ....|____||__|__\_____ .=.| _---\__|__|_---_|. .........O..Chris....O Last edited by Herald1360; 17th Jul 2017 at 1:10 pm. |
