19th Jul 2017, 2:41 pm | #61 |
Re: King's speech unedited BBC recording. Value?
Yes, but AFAIK Columbia had standardised on 78 by 1930.
Martin
BVWS Member |
19th Jul 2017, 2:58 pm | #62 |
Interesting to see "Start Outside" on the label, for recorded plays etc. that where longer than one side broadcasters alternated "Outside Start" and "Inside Start" to make it sound the same when changing disks. The inside is always worse than the outside.
19th Jul 2017, 3:01 pm | #63 |
The same applies to dual-layer DVDs.
19th Jul 2017, 6:00 pm | #64 |
Presumably for no "hiccup" since digitized stuff should sound the same when reconstituted whatever part of the disc it's recorded in.
19th Jul 2017, 7:03 pm | #65 |
Yes, I imagine the DVD situation is to minimise head movement between the end of layer one and the start of layer two. With "groovy" discs this wouldn't apply as it is necessary to move the head out of the way to turn the disc over, so restarting at the same linear speed makes sense to avoid a jump in sound quality.
19th Jul 2017, 8:57 pm | #66 |
CDs and DVDs are CLV (constant linear velocity) though (at least, during playback; recording can be done at constant angular velocity, only slowing down if the data buffer is getting emptied faster than it is filling up). They speed up towards the centre, so as to keep the number of bits per metre constant.
I can see why records were CAV, though ..... it would be a nightmare to implement CLV in the mechanical domain!
19th Jul 2017, 9:05 pm | #67 | |
Mind you, when you look at the mechanical intricacies of the analogue/mechanical era I am surprised that they did not come up with something! |
19th Jul 2017, 11:47 pm | #68 |
Fusée turntable....
20th Jul 2017, 8:57 am | #69 |
Interested in clocks and watches, perchance?
20th Jul 2017, 10:37 am | #70 |
Thanks everyone, I'm flat out with work at the moment by once I get round to playing it I'll let you all know how it goes
I will check the edge Hartley 👍 Have a great day everyone it's dinner time here in oz |
20th Jul 2017, 1:35 pm | #71 | |
Being 16-inch diameter, it's not straightforward to play, but my Collaro 4T200 transcription unit will just about manage it, thus justifying its description! Martin
BVWS Member |
21st Jul 2017, 3:07 pm | #72 |
If the groove spacing of the record were constant, a constant linear velocity turntable would be fairly simple to design.
21st Jul 2017, 10:50 pm | #73 | |
If I were you, in the first instance I would email these people:- https://www.nfsa.gov.au/contact-us/offices Include a link to this discussion. I have a feeling that they will be very interested. I am sure they can point you to somewhere in Perth where the record can be safely played and transcribed. It is possible that this could be an important historical artefact, but even if it isn't a lost episode of "The Goon Show" it may still be worth a bob or two ;-) Graham. G3ZVT |
22nd Jul 2017, 1:28 pm | #74 |
Hi Graham
Ive emailed them Thank you Suzy Last edited by Suzyperth; 22nd Jul 2017 at 1:44 pm. Reason: Update |
25th Jul 2017, 3:43 am | #75 |
Hi Graham just a quick up date the nfsa suggest I go to https://www.bl.uk/subjects/sound
Which doesn't really help im in Perth You wouldn't think it would be this hard to find out about a record with such a historical background ☹️ Thanks again Suzy |
