15th Jul 2017, 11:02 pm | #21 | |
Re: First Radio Build - 12V HT system
This is something you can alter in your favourite graphics editor. Quick fix is just to save an image as .jpg, which does not support transparency -- though it may cause visible artifacts on line art, as the compression was designed for photographs. Try it and see.
15th Jul 2017, 11:39 pm | #22 | |
EDIT- Upon rereading your post i realised I was clicking the wrong link for the calculator, I have done the calculation now and it doesn't seem to make much difference having a higher capacitance. I will need to modify the coil it seems. Last edited by bobskie; 15th Jul 2017 at 11:44 pm. |
15th Jul 2017, 11:41 pm | #23 | ||
16th Jul 2017, 8:36 am | #24 |
Re: Post#22, a 500pF variable capacitor will tune the MW band with a suitable coil, but not with the 5uH coil that's shown in the schematic, to get a graphical understanding of what's going on have a look at the nomograph in the picture below, draw a line between an inductance value and a capacitance value then read off the frequency scale the resonant frequency in kHz of that LC combination. In that pic micromicrofarads is the same as picofarads (pF)
Lawrence. |
16th Jul 2017, 9:04 am | #25 |
Thanks for all the help I have learned a lot. That scale certainly cleared things up a bit. I feel a bit more confident in building the coil now but im sure I will be back here asking more questions when the time comes
Cameron |
17th Jul 2017, 3:32 pm | #26 |
Im back again with another question, which resistor in the diagram is the volume pot? The regeneration control is marked as a normal resistor too and I can't work out which is volume. Thanks.
17th Jul 2017, 5:47 pm | #27 |
The 100k pot is the volume control, it needs to have a logarithmic (log) track.
The 50k pot is the regen control, a linear (lin) track would be the type to go for I would say. Lawrence. |
17th Jul 2017, 5:59 pm | #28 |
I wasn't even aware of the different types, fortunately I bought a linear 47k for the regeneration control. How do you tell the difference between the types? I have a couple lying around that may well be the correct value which I will need to test. I suppose it's safe to assume one used for volume would be logarithmic?
Cameron |
17th Jul 2017, 6:40 pm | #29 |
Sometimes it's printed or stamped on the case, Log, Lin, sometimes it's a letter code such as A or B, with those codes though there's no definite rule, in most cases A will be Log and B will be Lin but for whatever reason it can sometimes be the other way round.
If a pot isn't marked Lin or Log you can check which type it is by measuring the resistance between one end of the pots track and the pots wiper then the other end of its track and the wiper, both measurements taken with the pot's shaft set to the mid rotation position, if those two resistance measurements are in or roughly in agreement then it will be a Lin pot, if the two resistance measurements differ by a factor 9 (approx.) then it will be a Log or Anti log pot, Log pots are the most common type compared to Anti log pots. For more info do a google image search for...... log lin pot curve ......plenty to look at and read about. Yes, volume pot would be a log pot. Lawrence. |
17th Jul 2017, 6:42 pm | #30 |
Assuming all pots are either log or linear law (there are other laws, some quite exotic, but you are unlikely to come across them) :
Set the pot spindle to the mechanical mid postion. Measure the resistance between the wiper (middle terminal ) and each of the outside 2 terminals. If the 2 resistances are about the same (and equal to half the nominal resistance of the pot) then it's a linear law one. If they are wildly different it's log law. [Crossed with MS660] |
17th Jul 2017, 6:52 pm | #31 |
Well I will need to measure those pots. I've learned so much and I haven't even started building the radio yet!
17th Jul 2017, 7:55 pm | #32 |
You don't "need" a log volume pot, an linear will work just as well , it will feel a bit different using it though.
17th Jul 2017, 9:20 pm | #33 |
I have ordered up a logarithmic pot now the three I had were far lower than 100k.
18th Jul 2017, 12:41 am | #34 |
ISTR about 50 turns on a typical ferrite rod will be about right for medium wave. Tap at about 8 turns from the "bottom".
You may not need an external aerial for local signals at all with the rod type coil.
18th Jul 2017, 1:21 am | #35 |
Nice to see someone having a go at building a set from scratch. Takes me back to my youth and building projects out of Practical Wireless. Paul. |
18th Jul 2017, 12:00 pm | #36 |
I will need to experiment with different coils, it would be handy to have reception without an external antenna but ferrite rods can vary so much for the calculation. It should be interesting trying to get that wire wrapped correctly. Does anyone have a good guide on doing it and how to create a tap etc? I can't seem to find a clear explanation.
Cameron |
18th Jul 2017, 1:30 pm | #37 |
Simplest- get hold of some wirewrap insulated wire or even the thinnest PVC insulated wire you can get hold of. Wind on 8 turns, form a loop of whatever length you may need to reach its connection point in your build by twisting about half an inch together, then wind on the rest. Secure the coil on the rod using hot melt glue, ty-raps or even just sticky tape. leave the top tail long enough to add turns if needed for the right frequency coverage, removing a few is easy anyway.
18th Jul 2017, 3:28 pm | #38 |
Sounds simple enough though I expect it will be a bit harder in practice. I have bought some enamelled wire I'm just awaiting it's arrival. Thanks for the help
18th Jul 2017, 5:17 pm | #39 |
Enamelled wire? That's just gilding the lily
Just the job, really. You'll have to use a varnished bog roll core as a former though
20th Jul 2017, 2:11 pm | #40 |
Today I started assembling the circuit board(a piece of wood with nails in it). I notice that in the diagram the regeneration pot appears to have both connections on the outside legs. Is this correct? I can't see how it would function like that. Am I also right in saying that all three pins of the 100k pot are being used to create a voltage divider?
Cameron |
