Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval. |
10th Jun 2017, 8:34 pm | #1 |
PM Quota limit.
Does the forum software inform a member when (s)he needs to clear some space to receive more PMs?
I'm trying to reply to a PM from EF80TVVALVE. |
10th Jun 2017, 8:46 pm | #2 |
Re: PM Quota limit.
I have had a PM 90% full warning recently, so I would say yes, the forum does warn you when you are nearing your limit.
Alan. |
10th Jun 2017, 9:01 pm | #3 |
Re: PM Quota limit.
Thanks Alan.
11th Jun 2017, 9:18 am | #4 |
Re: PM Quota limit.
Hi Col, the box at the top right on the main menu screen gives both % full and total (sent received ) posts.
Ed |
11th Jun 2017, 2:25 pm | #5 |
Re: PM Quota limit.
Mine only gives the total - no percentage. The latter is, however, easy to calculate by dividing by five (unless you're a moderator, who I seem to recall have a higher allowance than the standard 500 - and need it!)
11th Jun 2017, 3:14 pm | #6 |
Re: PM Quota limit.
Yes we do.
If you go into private messages you get another box. This one gives both your total and your allowance, but leaves you to work out the percentage. It also has the command to empty the folder, but there are options at the bottom of the page to save them first. |
11th Jun 2017, 4:41 pm | #7 |
Re: PM Quota limit.
My browser shows it as a bar graph so that the % can be estimated visually.
11th Jun 2017, 6:55 pm | #8 |
Re: PM Quota limit.
There's also now a big red warning banner that comes up when it gets full.
12th Jun 2017, 5:36 am | #9 |
Re: PM Quota limit.
Isn't there an option to send folk emails too? Helps if their box is full up.
Andy.
12th Jun 2017, 8:24 am | #10 |
Re: PM Quota limit.
There is if the member agrees to receive emails via the forums. To use this option click on the member's username to the left of their post and select it from the drop down menu.
The email will be sent without either member having their email address revealed.
