31st May 2017, 9:49 am | #1 |
Anybody recognise this "Noval" car boot find?
Hello,
Does anybody recognise this French radio, the only thing that I can see on it is "model NOVAL" The valve line up is ECH81,EF41,EBC41,EC41,GZ41 and magic eye indicator EM34 I was told "it works!" ...but I have made no attempts yet. Any ideas as to where to find a circuit diagram would be wonderful! Many thanks in advance Philip |
31st May 2017, 10:28 am | #2 |
Re: Anybody recognise this "Noval" car boot find?
You could try one of the French forums listed in this thread:-
https://www.vintage-radio.net/forum/...ad.php?t=49827
31st May 2017, 10:29 am | #3 |
What a tremendous find!
The output valve will be an EL41, not an EC41. |
31st May 2017, 10:31 am | #4 |
That symbol on the grill look like the one used by Radiobois; Paris
I don't think they have this exact model in the Radiomuseum though http://www.radiomuseum.org/dsp_herst...pany_id=5155#a Cheers Mike T
31st May 2017, 10:35 am | #5 |
I wonder if who ever it was made this one too:
http://www.tsf-radio.org/forum/im/231269p1010410.jpg Linked from: http://www.tsf-radio.org/forum/forum.php?show=231269 Lawrence. |
31st May 2017, 12:12 pm | #6 |
'50s French radios of this ilk were pretty much generic. Find one with the same valve lineup and chances are the circuit will be near enough.
It's got a bog standard Mullard/Philips valve lineup anyway; unless the designer was on trop de vin it'll likely be derived straight from the applications data of the day. Nice find by the way- I've got a soft spot for the more outrageous French sets of the period.
31st May 2017, 12:18 pm | #7 |
Mention of glass tube caps reminds me of a Schneider set I have. I suppose other makers in France used them too, but the pierced part back, holes rather than slots, is also very Schneider ish. That's a new word for google.
The back on my set has a model name only too. |
31st May 2017, 12:28 pm | #8 |
That's interesting, until now I hadn't realized that there was such a thing as a GZ41.
31st May 2017, 12:38 pm | #9 |
The badge thing on the grille looks the same as the one shown on this page (scroll down to post 2821):
http://radiofil.com/petites-annonces...ts-tsf-36.html Lawrence. |
31st May 2017, 12:58 pm | #10 |
I don't think British manufacturers used it at all, but it was quite popular in France, as was the AZ41.
31st May 2017, 3:22 pm | #11 |
I wonder if it originated from Oceanic?
Lawrence. |
31st May 2017, 3:25 pm | #12 |
Wow - nice ...... and not as outrageously 'Baroque' as some French offerings !!
Red to red, black to black. Throw the switch and stand well back! |
31st May 2017, 3:38 pm | #13 |
There's also a Spring 53 with the same badge on the grill cloth as in post#9...So near yet so far.....
http://pastpluspresent.blogspot.co.u...anciennes.html Lawrence. |
31st May 2017, 4:05 pm | #14 |
Thank you for responses so far, certainly making progress
The EC41 was a typo by me Is it possible that the ECH81 is not the original and is replacing a ECH41 or 42 (or is that not how it works?)as I don't seem to see any totally matching line ups? Many thanks Philip |
31st May 2017, 4:36 pm | #15 |
Getting close...?:
https://www.doctsf.com/grandlivre/fi...ef=6951&ori=ps Schematic for above: https://www.doctsf.com/documents/aff...1174&num_fic=1 Lawrence. |
31st May 2017, 5:27 pm | #16 | |
Also look out for capacitors valued in cms. 1cm is about 1.11pF. It's the old cgs unit for capacitance. Unless it's tuning something, 1cm = 1pF is close enough....... I reckon Lawrence's find is close enough! There's several other "modeles a identifier" with very similar layouts and lineups so the chassis probably is a generic one shoved into the local shop's choice of cabinet.
31st May 2017, 5:55 pm | #17 |
The IFTs look very off the shelf Phillips too.
31st May 2017, 6:52 pm | #18 |
I suspect some people like me are thinking , How much was it you lucky well done in finding it , Mick.
31st May 2017, 6:59 pm | #19 |
Yes I'm another It's in pretty good cosmetic condition too. Excellent find.
Andrew
31st May 2017, 9:27 pm | #20 | |
French manufacturers seemed not to trust the heater-cathode insulation of the EZ80 / 81 at first (even although it was under less voltage stress than that of a UY41 / 85 would be), and persisted longer with separate rectifier heater supplies while others used single supplies.
