5th Jul 2017, 6:46 pm | #41 |
Re: Dansette Major Deluxe
Thanks for that I think it is starting to get above my head, may be better to find someone who I can send the whole lot to to be renovated.
Michael. |
5th Jul 2017, 8:30 pm | #42 |
If you want to go down that path, you could try a post in this section: https://www.vintage-radio.net/forum/...play.php?f=145
6th Jul 2017, 10:01 am | #43 |
Mike sent me a video of this and as far as I can see it is definitely suffering from inductive pickup. I'll happily forward the video to any member who PM's me their email address.
There is nothing wrong with the smoothers. They've were replaced prior to my receiving the amplifier for repair. I tested them and they're all OK. See my detailed report in posts #30, #32 and #36. I did note that the connections from the amplifier to the volume control and hence to the pickup did not use screened wire. Whether this was normal for a Dansette I don't know. I guess this illustrates that repairing the amp in isolation from the player is not a good idea. I certainly won't be doing it again. I've attached a still from Mike's video. With the input wire held like that it's little wonder there's a drone and there's no evidence of the wire having been twisted. A picture showing the connections to the tag strip under the deck and to the cartridge would help.
6th Jul 2017, 12:15 pm | #44 |
MODS: I did Post a reply to this, but we have had several Outages here and it may not have been sent:
Yes, Dansettes of this period did use the 2 signal wires twisted together and somehow they usually got away with it. I suggest the OP twists together the red and black wires and re-connects to see if the hum has reduced. Better still, to get a short length of single screened lead from Maplins and use this. it will only need 4 soldered connections.
Edward. |
24th Jul 2017, 4:56 pm | #45 |
My thanks to Ed who has got the Dansette working a treat, sounds good He fitted some shielded wires, fixed a loose capacitor and a problem on the circuit board and sorted wiring to the cartridge, now to fit new stylus, 78 and 45 and then should sound brill.
Many thanks Ed. |
