Old 28th Mar 2017, 7:28 pm   #1
vinrads
Default Columbia DC radio
And now for something different. This it a DC only radio the valve line up is
DCPen DC hl DCsg DC2sg All very rare valves , The story is when I bought the radio they were two valves missing ,the only DC equiv were different voltages and different current ,and these took some finding.
The voltage for the heaters came to 40 volts but the two replacement were only 0.1a whereas the two original were 0.3a so a shunt resistor was fitted accross the two 0.1a ones.
I proceeded to construct a power supply to supply 40v DC and HT about 180 volts.a 120 volt tx was used for the ht and a low voltage one for the heaters , Bridge rectifiers were used in both HT and LT .That's the power supply on it's own shelf top r/h corner of the cabinet.
All the usual capacitors in the can's were replaced , the chassis was very clean for it's age ,but the cabinet req a total strip and re lacquering .
The set works very well as with all TRF set you have to know how to drive them . Mick.
ID:	139993   Click image for larger version
ID:	139994   Click image for larger version
vinrads is offline
Old 28th Mar 2017, 11:50 pm   #2
Phil G4SPZ
Phil G4SPZ's Avatar
Default Re: Columbia DC radio
What a fascinating radio. Well done on restoring it, there can't be many DC mains radios still in existence, let alone working. Brilliant job!
Phil
Phil G4SPZ is offline
Old 29th Mar 2017, 7:39 am   #3
Nickthedentist
Nickthedentist's Avatar
Lovely cabinet, in an elegant and understated way,
Well done, Mick!
Nickthedentist is offline
