Old 15th Jan 2017, 1:50 pm   #1
EF80TVVALVE
EF80TVVALVE's Avatar
Default Running the Auroras RF modulator only
Hi, reading the instructions for the SCRF Aurora it says that the RF modulator can be used alone. Does anyone know how I set the aurora to do this as I have some 405 tape that I would like to run through it.
Bren
EF80TVVALVE is offline
Old 15th Jan 2017, 6:16 pm   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: Running the Auroras RF modulator only
I think you just feed audio /video in and the testcard goes off.
HamishBoxer is offline
Old 15th Jan 2017, 6:34 pm   #3
Dave Moll
Dave Moll's Avatar
So, does that mean that it automatically detects whether the input is 405-line or 625-line - bypassing the converter in the former case?
Dave Moll is offline
Old 15th Jan 2017, 6:43 pm   #4
Roy
Roy's Avatar
One of the option switches inside needs to be set to make the Aurora operate as a modulator only.
Switch No. 8 on the earliest ones, No. 6 on later ones. The paper label will confirm.
I have used this option for 405-line VHS and it works fine.
Roy
Roy is offline
Old 15th Jan 2017, 7:49 pm   #5
Roy
Roy's Avatar
Update:
My Aurora was one of the earliest. You may find that yours is a different version if you have purchased it recently, and the method for enabling modulator-only operation may have changed.
Instructions for all versions are available on the Aurora website.
http://www.tech-retro.com/Aurora_Des...downloads.html
Roy is offline
