Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 10th Jun 2017, 8:34 pm   #1
ukcol
ukcol's Avatar
Default PM Quota limit.
Does the forum software inform a member when (s)he needs to clear some space to receive more PMs?
I'm trying to reply to a PM from EF80TVVALVE.
ukcol is offline
Old 10th Jun 2017, 8:46 pm   #2
Biggles
Default Re: PM Quota limit.
I have had a PM 90% full warning recently, so I would say yes, the forum does warn you when you are nearing your limit.
Alan.
Biggles is offline
Old 10th Jun 2017, 9:01 pm   #3
ukcol
ukcol's Avatar
Thanks Alan.
ukcol is offline
Old 11th Jun 2017, 9:18 am   #4
Ed_Dinning
Hi Col, the box at the top right on the main menu screen gives both % full and total (sent received ) posts.
Ed
Ed_Dinning is offline
Old 11th Jun 2017, 2:25 pm   #5
Dave Moll
Dave Moll's Avatar
Mine only gives the total - no percentage. The latter is, however, easy to calculate by dividing by five (unless you're a moderator, who I seem to recall have a higher allowance than the standard 500 - and need it!)
Dave Moll is offline
Old 11th Jun 2017, 3:14 pm   #6
AC/HL
AC/HL's Avatar
Yes we do.
If you go into private messages you get another box. This one gives both your total and your allowance, but leaves you to work out the percentage. It also has the command to empty the folder, but there are options at the bottom of the page to save them first.
AC/HL is offline
Old 11th Jun 2017, 4:41 pm   #7
Refugee
Refugee's Avatar
My browser shows it as a bar graph so that the % can be estimated visually.
Refugee is offline
Old 11th Jun 2017, 6:55 pm   #8
Nickthedentist
Nickthedentist's Avatar
There's also now a big red warning banner that comes up when it gets full.
Nickthedentist is offline
Old 12th Jun 2017, 5:36 am   #9
Diabolical Artificer
Diabolical Artificer's Avatar
Isn't there an option to send folk emails too? Helps if their box is full up.
Andy.
Old 12th Jun 2017, 8:24 am   #10
There is if the member agrees to receive emails via the forums. To use this option click on the member's username to the left of their post and select it from the drop down menu.
The email will be sent without either member having their email address revealed.
Station X is offline
