14th Dec 2011, 11:44 am | #161 |
Re: Vintage Christmas Tree lights
Very nice display John, I think I would have to re-inforce the TV22 cabinet in order to get my tree on top like you have done there , this tree also has a tendency to drink two pints of water a day!.
Neil
16th Dec 2011, 8:37 pm | #162 |
Tip! Please forgive me if anyone has previously mentioned this. If you want your old Christmas tree light set lamps to last for ever, wire any silicon diode such as a BY127 in series with the 'live' wire similar to the later television heater chains. They are not so bright but still great.
[I have been waiting for years for the Geraniums to produce enough crystal to make a detector but so far, nothing. Any green fingers guys know what I'm doing wrong?] John. |
17th Dec 2011, 1:09 am | #163 |
Does anyone know the specs for the 8-lamp MES-base sets? A mate of mine has a lovely string of lava-lamp lights and 1 lamp has broken. They look like an old golfball side-lamp as fitted to some 1950's cars.
Kevin |
17th Dec 2011, 1:18 am | #164 |
Real Christmas tree lights on a real tree with the correct connectors , a real fire and a proper television ! spot the item that is not 1950s
Happy Christmas Peter |
17th Dec 2011, 3:27 am | #165 | |
Double check that they ARE for UK mains though, 8 lamps in series is more of a USA thing, 8 lamps each 15/16 volts for series use on 120 volts. Replacement lamps must be the same current as well as the same voltage, unless replacing them all. 32 volt MES lamps are still made, but are unlikely to match the originals. |
17th Dec 2011, 9:46 am | #166 |
It must be something to do with the fireplace Peter. There is a curious 'doll' thing on the left of the mantle and possibly a 60's cat on the hearth. It does look very much like a middle class living room from that period, very cosy with a nice 'safe' feeling from childhood days.Well done. Maybe the Bush TV22 should be replaced by the console TUG24 to make it 100% correct. Yes Geof, I thought someone would have mentioned the series diode. It was a long way back!Regards, John.
PS. Is the 'doll thing' a modern fairy? Last edited by Heatercathodeshort; 17th Dec 2011 at 9:52 am. |
17th Dec 2011, 1:35 pm | #167 |
These are my lights that I repaired a few years ago, some of the holders needed resoldering and the foil stars are held together with clear tape, I keep them stored around a card and in a box. The open plug shows the rectifier in the neutral lead, the loose bulb has a broken filament. I have a few other sets of old miniture and lantern lights, one set of which usually goes on the plastic tree which is also quite old.
24th Dec 2011, 6:46 pm | #168 |
Had a bit of a shift around with the 'Christmas Telly'. Swopped the Ultra 15" for the Ekco TSC112 12" console. It was manufactured in 1949 so is exactly the same age as the bungalow. The Christmas tree does not like the sloped top. It is only a small room and the Ekco looks more in place. Happy Christmas. John.
31st Dec 2011, 5:32 pm | #169 |
I've always wanted a set of vintage screw in lights so after seeing the pictures i must make sure i get a set for next year!
"Oh yes I love television, all those wiggly lines"! |
31st Dec 2011, 5:42 pm | #170 | |
But I think my set must have been pretty much the first LED Christmas tree lights around. They were a real talking point at the time. Craig |
1st Jan 2012, 5:22 am | #171 |
I built a disco light chaser, as you do, and ran four sets of (modern, for the time - late 1980s) tree lights from that. Even had it rigged up to the printer port of an old XT clone (I had built in an expansion port with the 8 program steps, 4 opto-isolated lamp inputs and reset, plus power and earth) one year. The chaser actually has one of the first blue LEDs (which IMMSMW set me back most of £5 at the time) incorporated into its mimic display. Maybe I should dig it all out before twelfth night!
1st Jan 2012, 12:32 pm | #172 |
I have enjoyed this thread, modern LED light just doesn’t do it for me, I like my sets of Pifco Merrylites and Noma lights the oldest being the daisy ones which I found at a carboot.
It’s not Christmas without spending a few hours testing and replacing bulbs, it’s always the last one isn’t it. Lee |
2nd Jan 2012, 4:49 pm | #173 |
I agree, Lee. The LED ones are far too bright and glaring.
5th Jan 2012, 12:58 am | #174 |
Hello all, I've really enjoyed this thread and managed to get a nice vintage set of Osram olive lights before christmas. We had a set of 12 Noma Olive cone lights in the 60's.
Inspired by others, I put a dimmer on a board with a BC socket. The pictures on here have been most festive. Thanks for sharing. I thought I'd just get this on before 12th night. David. |
22nd Jan 2012, 7:49 pm | #175 | |
Regarding the short life with external lamps run from 24V transformers, in all my sets the transformers have delivered significantly more than 24V when measured at the lamps, and I have reduced this by connecting wire-wound 7W resistances in series on the low voltage side. In what was intended to be a temporary lash-up, I attached 2 pairs of "chocolate block" insulated terminal strip connectors to the transformer casing with adhesive “Velcro” and mounted pairs of resistors between them. As they don’t get appreciably warm in use, this has become semi-permanent, the "Velcro" mounting allowing the resistors to be removed for packing away in the original box. As the outdoor lights have thermal flashers I bought a selection of resistors from Maplin in the 1 to 10 ohm range and experimented to find the highest resistance combination that still allowed the flashers to operate. When I couldn’t get replacement 20V 3W lamps for our old 12 light set I added 4 extra holders from the remains of another set and used some 12V 100mA screw bulbs until I was able to find some 20V replacements. Although the current ratings don’t match in theory, they worked OK in practice. I also converted the looped arrangement to single ended by running a wire from the last bulb back to the plug and twisting it with the original wires. I haven’t had any fail since. We used to have a BC in-line mains flasher but as a schoolboy I inadvertently destroyed it by trying to use it with a 100W bulb, not appreciating the signifiance of its 40W max rating! Clear bulbs (or faded coloured bulbs) can be painted/rejuvenated with transparent paints by “Humbrol” ( red, amber, green) and “Revell” (blue) that can be got in shops that sell plastic model kits, especially if the lights are used indoors or in sheltered positions outside. However, after a couple of weeks draped around our hedge in wet weather, the blue ones were fine, but the others were markedly faded. Last edited by emeritus; 22nd Jan 2012 at 7:54 pm. |
29th Jan 2012, 5:20 pm | #176 | |
Glad to say seven of the original bulbs still work, including the "bunch of grapes", and of course Santa himself. Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. |
31st Jan 2012, 9:06 am | #177 |
We had a set like those bought from Woolworths in the early 1960s so yours may be a little older than you suggest. Are you going to modify them to reduce the voltage a bit? Unfortunately they don't seem to last very long with the full 20v on each bulb.
19th Feb 2012, 10:41 pm | #178 |
Am new to the this site and also like vintage lights. Do you think the old transparent green wire on the Pifco light sets is more robust than the modern fairy light wiring? I don't recall seeing many low voltage lights sets of vintage style but do you think low voltage transformers are reliable or is it always better to buy mains operated? Some people say mains lights pose a fire hazard whether this is true I don't know.
20th Feb 2012, 9:56 am | #179 |
The old type of wire often transparent, is arguably LESS robust than that used on modern mains voltage Christmas lights. Present day regulations are stricter and would not permit the use of mains voltage on the thin single insulated wire formerly used.
Christmas lights that use a reduced voltage from a transformer have only become popular in relatively recent years, in the old days transformers were relatively costly items and therefore not widely used if not essiential. The transformers are vary a lot in reliability. Transformer operated lights are often rather dim when compared to mains ones as the lamps are usually of much lower power. Transformer operated lights are arguably safer, almost no risk of dangerous shock, and reduced fire risk. If you wish to use old or vintage lights, these should be carefully inspected for any faults or damage, consult an experienced electrician if in doubt. If in good condition, they are resonably safe to use, but perhaps less so than modern ones. I would put them out of reach of children and pets, away from flammables, and think twice about unattended operation. Use of an RCD reduces the shock risk, and an isolating transformer almost eliminates it. Fitting a 1 amp fuse in the plug reduces the fire risk. Use of a reduced voltage can greatly prolong the lamp life. This may be achieved by a variable transformer, or a fixed step down transformer, or by inserting series resistance, or by connecting a greater than intended number of lamps in series, or use of a lamp dimmer. |
20th Feb 2012, 11:18 am | #180 |
A rotary lamp dimmer also provides soft-start. I have one in my living room controlling a handful of halogen downlighters, and the lamps are nearly 10 years old with no failures so far.
The "chopped" output might seem harsh, but in practice, the net effect seems to be to reduce lamp failure at switch-on considerably. N. |
