13th Mar 2017, 4:37 pm | #1401 |
Re: The "Sussex" Homebrew Valve Tester.
14th Mar 2017, 9:22 am | #1402 |
Many thanks Bill.
George. |
14th Mar 2017, 4:24 pm | #1403 |
My thanks to you as well Sam.
Regards. George. |
14th Mar 2017, 4:43 pm | #1404 |
I have recently noticed that there are now two diodes across R12 in the circuit diagram, was this to give some extra protection to the GM meter?
With my tester I appear to get rather high GM readings, any suggestions? George. |
14th Mar 2017, 10:56 pm | #1405 |
Have you fitted R6 on the PCB - it's not shown on the layout on P26 of the manual - assuming you are using the original board layout. The holes are there between AJ & AK - top right of the drawing.
Have you checked the audio osc output level that feeds to the grid? The extra diode added in series with D16 was fitted for a reason, but I can't remember why now, but it's described somewhere - found it on page 23. |
16th Mar 2017, 9:27 am | #1406 |
Many thanks vidjoman for that, will take a look but almost certain R6 would have been fitted.
The osc O/P has been set to the correct level when I first set up the neg supply circuit. Putting another diode in series with D16 will require a bigger voltage across R12 before conducting, sounds obvious I know, but will put another one in series and see. Again thank you. George. |
16th Mar 2017, 9:33 am | #1407 |
My version of Mike Rowes "Sussex"
21st Mar 2017, 9:15 am | #1408 |
Sorry, worded that wrong should be a bigger voltage across the diodes in order for the two to conduct, must be my age !!
30th Mar 2017, 12:37 am | #1409 |
Hello, I've recently (about 3/15/2017) received the latest version of the main circuit board from Martin (thank you Martin) and I'm having difficulties locating the value of C15. I'm not finding C15 in the parts list or schematic.
Also, are there any known issues with the latest version of the main PCB that will need correction when I'm populating the board? Thank you, Dave Bacon |
31st Mar 2017, 2:11 am | #1410 |
Hi Everyone, concerning my recent post (#1409) about C15 on the main PCB, I also checked with Martin C. on this and his very helpful reply was that C15, R102 (which I was also wondering about), and D17, "are the snubber components across the HT relay (RL1) contacts introduced in post #1308.
Martin C. continued to mention that "A resistor of some 390 Ohm, a capacitor of some 220nF @ 630V or 1kV and a diode like UF4007 (or some better diode with higher current rating) will work fine for this snubber." Martin C. also reports that "They are optional and there have been no problems reported on earlier issue boards which didn't have them." To be honest, as a novice electronics hobbyist I had never heard of a "snubber circuit" before but found this very helpful site explaining how snubber circuits are used to protect relay contacts. (A perfect learning opportunity for me) http://www.hiquel.com/fileadmin/user...te_EN_0100.pdf I'm making excellent progress towards gathering all of the components for my Sussex Valve Tester build. My goal for this build is not only to have my own valve tester, but to also increase my knowledge about electronics and valve (vacuum tube) theory. Take care, Dave |
4th Apr 2017, 2:04 pm | #1411 |
Hello Dave,
A snubber should always be used when relays are switching inductive loads. Hope the building of the "Sussex" is continuing well, very much enjoyed building my version of Mike Rowes design and the help I received from "topcap" and others. George. |
6th Apr 2017, 10:54 am | #1412 |
Hello everyone,
My name is György Szabó, you can call me George. I live in Norway. I've recently found this forum and I'm very happy about it. I have to give respect to the author and say thank to you guys for developing such a useful instrument. I have read the thread and all available docs so will begin to build the tester in a short time. I have seen many of you has built this tester and all of them has a different look. I understand that everyone has it's own needs/possibilities in design. But I have to ask, is there a need for a more or less standardized design of the front panel for this tube tester? I mean an aluminium sheet panel with all the sockets and controls installed on it. Of course with some extra space for installing extra sockets/controls if needed. A simple design in DXF can be made in a short time. I have a homemade CNC machine which can drill/mill soft metals e.g. aluminium (beside wood) and I have successfully machined a few top panels for my tube amplifiers. I'm going to build this tube tester and I would like to make a nice front panel to have a look similar to a Heathkit or Hickok for example and I want to share it with you. But in order to be useful for others as well I want to discuss it with you and make it maximum usable not only for my needs. So what you think about this? Is it worth discussion? '73 George, LB4IG |
7th Apr 2017, 7:53 am | #1413 |
You have a very famous surname, I wonder if you were related to Violette?
Regards. George. |
7th Apr 2017, 8:07 am | #1414 |
Personally, I feel that the Sussex can be built to suit the needs of each individual. That is one big advantage. My own has only three sockets because I really only test audio valves, so I don't need to have the facility for a greater range.
Similarly, the layout of the panel is up to the builder's own preference and resources. Mine, a photograph of which is in the User Manual, was rather determined by a 3U rackmount case I had to spare, so everything is built so that the controls are on the front panel and the valve bases are on the top. The top panel is large enough to punch for new sockets if I need to at a later date.
7th Apr 2017, 1:00 pm | #1415 |
3rd May 2017, 8:01 pm | #1416 |
Hi, I am having a problem testing a PX4 valve on my Sussex. I have not tested a directly heated valve before so maybe it's me doing something silly.
I connect the ext-heater -ve terminal to the cathode and then connect up the valve as normal. But I am getting massively off readings like Gm=100 and Ia=80mA I am expecting something like 40mA and 6. Any ideas? |
5th May 2017, 2:47 am | #1417 |
With a directly heated valve you have to run the heaters from DC. Use an external DC power supply giving 4V at 1 Amp. You must use the jumper of course between ext-heater -ve terminal and the cathode.
5th May 2017, 1:01 pm | #1418 |
Hi Top Cap, glad you were looking! Yes of course that helps and now I get sane results.
I have never come across directly heated valves so it is probably just my ignorance. But I wonder if this is worth clarifying in the Sussex manual? In the valve testing steps (pg 47) perhaps it would clarify by separating by direct from indirect? |
5th May 2017, 6:36 pm | #1419 |
Good point. I'm planning a manual update soon so I'll incorporate that information.
Keith |
23rd May 2017, 9:08 pm | #1420 |
This may be of interest to builders of the VT1 The oscillator in mine varied from 100mV to about 160 mV on warm up. Looking at the oscillator circuit I was puzzled by the inclusion of D6 - it was not needed for the phase shift oscillator to function. Warming it caused the oscillator output to increase quite considerably, so I decided to remove it. This improved the regulation but it was still not satisfactory. I then decided to reverse this diode and found that my oscillator did not vary at all from the 100mV setting even from a cold start.
