Old 29th Mar 2017, 12:30 pm   #1
Panrock
Panrock's Avatar
Default 'Shadow' on VHS machines playing 405
I bought my first VHS machine in 1982. It was a Fisher FVH-530 (if I recall the number correctly) and lasted for twenty years of regular use until it got 'sluggish'. I was then given a JVC HR-D180EK, which I have to this day and still works well enough. You may gather from this I have never got into servicing video recorders!
I have used both machines with my collection of 405-line VHS tapes. The picture is very sharp due to the less stringent bandwidth requirement on 405. Sometimes, on worn tapes the incorrect dropout compensation timing can be a pain, but I think of this like 'ignition interference'.
On the later JVC machine, there is a faint shadow two-thirds across the picture. This is where the machine presumably expects the next 625-length line to begin.
What internal feature is causing this? Has anyone done a survey of which machines do and do not exhibit this effect? Can anything be done about it? It never seemed to be reported on the early machines.
Steve
https://www.radiocraft.co.uk
Panrock is offline
Old 29th Mar 2017, 3:31 pm   #2
1100 man
1100 man's Avatar
Default Re: 'Shadow' on VHS machines playing 405
Hi there,
I recently experimented with a Ferg 3v29 vcr to record and play 405 material. There was a very noticeable shadow on playback. Gave a very good impression of 'Ghosting' though- quite authentic!
After a bit of experimenting and a look at the circuit, it turned out to be the drop out compensator circuit getting confused. I just grounded the input to the DOC input on one of the signal processing chips and it all worked very well.
If you need exact details, I will dig out the manual.
I can't rightly remember if my 3v22 did the same but I don't think it did. I don't think it has a DOC anyway.
Certainly my CV2100 ACE works (or used to before it spent 10 years in the barn) perfectly on 405.
Cheers Nick
1100 man is offline
Old 29th Mar 2017, 4:53 pm   #3
60 oldjohn
I had ghosting similar to Steve on a Ferg 3V31, 3 or 4 years ago so nearly forgotten but I seem to remember this was to be expected.
John.
60 oldjohn is offline
