28th Mar 2017, 4:08 pm | #1 |
Testing low voltage transformer.
Hi All.
Is there a relatively easy way of testing the safe continuous output current capability of a *large" low volts (30v) toroidal transformer? I have been donated this rather large item (which is potted) so I can't even get any clues from the wire gauge. Thanks Andrew
worried about the electrons entering the circuit and the smoke leaving Andrew |
28th Mar 2017, 4:13 pm | #2 |
Re: Testing low voltage transformer.
Its weight might be a useful indicator - compare it with data for similar ones in suppliers' catalogues etc.
Nick. |
28th Mar 2017, 5:05 pm | #3 |
A five percent drop on output voltage on load for large transformers is about right, more for smaller ones. It is fairly linear, load, measure and calculate, e.g. if it drops by 2% at 1 amp then 5% / 2% (2.5) gives 2.5A. When done load at the calculated maximum, a 60 centigrade rise is OK for modern units somewhat less (40) for older stuff.
28th Mar 2017, 9:40 pm | #4 |
It's the V-A rating of the transformer which you really need to know. As a guide, measure the core cross-sectional area, A, then use one of the two formulae:
1. If A is in mm.², V-A = A²/16042. 2. If A is in in.², V-A = 26*A². Either of those are approx. valid for conventional 'E-I' transformers at 50 Hz., in the range 10 - 100 V-A. Al. |
28th Mar 2017, 9:59 pm | #5 |
Hi Al.
It's a "big beast" encapsulated toroid 10" dia, 4" dia hole and 8" high. I got a "standard" E I transformer given at the same time. 18 volts 100A continuous.
28th Mar 2017, 11:28 pm | #6 |
Gauging transformers by weight has a degree of legitimacy. Jim Williams of Linear Technology wrote a lengthy section on it as part of LT's application note on switch mode PSUs...... Something like Power supplies for Poets.
