Old 25th Mar 2017, 9:53 pm   #1
ColinTheAmpMan1
ColinTheAmpMan1's Avatar
Default AVO Universal Measuring Bridge - Type 1
Does anyone have any knowledge of these instruments? It's the one that is rather like a suitcase with a removable lid covering the front. Are they reliable, are there any common faults and what might need replacing, if anything?
TIA, Colin.
ColinTheAmpMan1 is offline
Old 25th Mar 2017, 10:03 pm   #2
karesz*
Default Re: AVO Universal Measuring Bridge - Type 1
Hello Colin,
is here your AVO Bridge Type1? _or do you have in older version? Than on Vintage-radio too...
Regards Karl
Name:	AVO Universal Measuring Bridge - Type 1.jpg
karesz* is offline
Old 25th Mar 2017, 10:58 pm   #3
ColinTheAmpMan1
Yes, Karl. That is the very one.
Colin.
Old 26th Mar 2017, 7:27 am   #4
RobinBirch
RobinBirch's Avatar
I have one that I restored some time ago. If I recall correctly, I had to replace some capacitors, otherwise it works fairly well.
Robin
RobinBirch is offline
Old 26th Mar 2017, 8:14 am   #5
karesz*
Hi Colin,
did you chek these thread please, in last post, by Colin (your namesake?), is your SM.
Karl
karesz* is offline
Old 26th Mar 2017, 1:08 pm   #6
ColinTheAmpMan1
Hi Karl,
Yes, I did look at that. I couldn't fine a manual or a circuit diagram anywhere else. I think I will have to PM Colin Armstrong to get a copy of his scan.
Were the capacitors you replaced non-critical or were they the ones used as standards? I would hope that they weren't the standards; I imagine they could be pure "unobtainium".
Colin.
Old 26th Mar 2017, 1:45 pm   #7
pmmunro
If no-one has a scanned manual, I have one and could scan it.
PMM
pmmunro is offline
Old 26th Mar 2017, 8:21 pm   #8
Ed_Dinning
Hi Colin, they are a very useful bridge and easy to use. A little cleaning, lub of the slide wire is sometimes needed, but be gentle.
Ed
Ed_Dinning is offline
Old 27th Mar 2017, 12:44 am   #9
karesz*
Hi PMM,
Colin in link of#5 has a complette scanned manual and circuit as high res too.
Karl
karesz* is offline
Old 27th Mar 2017, 10:27 am   #10
WME_bill
Avo Universal Measuring Bridge Type 1. Suitcase style.
The complete manual is just too large to post on this Forum. I attach an extract which gives the key information. If you want the full manual, it will have to be sent by email.
Faults. Nothing out of the ordinary, but be careful of the main potentiometer, a 12" long horizontal tube wound with resistance wire, forming a slide wire. I had to rewind mine as it had worn and fractured in the centre of the track.
I have a spare bobbin of suitable resistance wire if you have to rewind.
wme_bill m0wpn
File Type: pdf Universal Measuring BridgeMkI_extract-wm.pdf (1.21 MB, 159 views)
WME_bill is offline
Old 27th Mar 2017, 6:03 pm   #11
RobinBirch
RobinBirch's Avatar
No, they weren't the standards, it was the more common or garden others that I swapped
