25th Mar 2017, 6:38 pm | #1 |
Marconi Marine Pantenna III
Hi all,
I have just picked up this Marconi Marine Pantenna III from a local charity shop and I have no idea what it is (preamp?). I can't find much information or pictures anywhere on the inter-web. Any information would be very appreciated. |
25th Mar 2017, 7:19 pm | #2 |
Re: Marconi Marine Pantenna III
Just opened it up. It's a Pantenna AM/FM Amplifier. Serial No. 1140.
26th Mar 2017, 12:55 am | #3 |
There's a reference here: https://www.vintage-radio.net/forum/...4&postcount=50
26th Mar 2017, 7:46 pm | #4 |
Harry, A 75 ohm coax would go from cabin to cabin, each cabin having an output box that had something simple like a 1K resistor and a .1 uF cap to feed a radio. The very far end of the coax was terminated with a 75 ohm resistor.
It would be most useful for all of us who have numerous receivers. You might site it and its aerial far from the house to minimise local qrm. I was most familiar with the Redifon valved version. Crew members would try and get better signals by opening up the box and tapping in. It was usually a devil of a job to find multiple faults and breaks in the line. Sometime the r/o would feed in a sig gen at about 600 kHz, modulating the sig gen with an HF receiver tuned to the BBC world service. 73, Andrew |
30th Dec 2019, 10:56 am | #5 |
Thanks for the photos of this unit - the manual has none. I got a manual recently, just to see some details. Further to what Synchrodyne said this comes in three versions to give additional Band II or Bands I+II distribution. The basic unit is specified for 100kHz -30MHz and includes filtering with sharp stopbands for the marine bands 370-550kHz and 1.6-4.0MHz. Four outputs are available to supply chains of up to 20 'outlets' in cabins, and slave amplifiuers were available to expand the capacity.
Further options were a high-impedance active antenna pre-amplifier and a modulator to provide a local feed of additional programme material as Andrew mentioned. DC and AC PSUs were offered. Main devices were BFY90 with a dual-gate 40822 MOSFET for the pre-amplifier. The stopband filter is a passive 14-pole unit. I attach the main schematics.
- Julian It's good here |
2nd Jan 2020, 1:05 pm | #6 |
I've parts of this system, which I rescued when I removed it to free up space on a bulkhead on one of my vessels. I hoping to use them as the basis of a "pantry transmitter."
I thought I had also rescued the complete manual, but can only find the circuits for the bits that I've got. Mike A |
2nd Jan 2020, 1:51 pm | #7 |
Mike - The only other bit of my manual which could be of use to you is the AM/FM diplexer unit, let me know and I'll scan that.
Regarding pantry transmitters, I'm sure we'd all like a view inside the modulator, the two coils being the only parts not specified on the schematic.
2nd Jan 2020, 3:41 pm | #8 |
Hello Julian,
attached photos of the inside of the AM Modulator. No Markings on the coils I'm afraid, however the circuit shows them both as "RP 208" Repanco? Denco? I assume they are off the shelf items. Marconi made coils would have had "WISxxxxx" or something similar written on the can. Regards Mike A |
9th Jan 2020, 12:05 am | #9 |
Thanks for that, Mike. Don't know why I never considered they would be in screening cans, but it should be easy to find a pair of suitable RF coils with matching taps or windings. A typical IFT with the fixed cap removed should give coverage of the lower half of MW, say 530-1,000kHz.
