24th Mar 2017, 7:13 pm | #1 |
Armstrong 521 noise
I am stuck with noise like thuder coming and going, only on phono input. In my experience normally transistor noise.
Replaced ME 4102 with BC547, and the two AC191 with AC151 I purchased. Noise is evident using a scope on C of the second transistor. Remove C 217 noise has gone. Have I got noisy new transistors? What cn I replace the AC191 with? Seems like NOS can give problems too. Thanks Stuart |
24th Mar 2017, 7:48 pm | #2 |
Re: Armstrong 521 noise
You should be able to replace the AC191 with any Ge general purpose type to confirm or eliminate the fault. An Si PNP type (BC558/2N3906 etc) could also be tried to see what effect it has on the noise, though you obviously wouldn't leave it there permanently. For a permanent replacement I would use an AC126 but there are lots of other types that would work.
Is the noise present on the BC547 collector? The BC547 isn't a low noise transistor and I wouldn't have chosen it for that position, though it shouldn't produce the symptoms you describe. A BC109/239/549 would be a better choice, or even a higher spec low noise transistor. |
26th Mar 2017, 7:02 pm | #3 |
Still noise, I have removed 211 cap between the first two stages and all is quiet. Noise on C of the BC549.
Caps changed, it must be around the first stage. What else can it be? Thanks Stuart |
26th Mar 2017, 8:37 pm | #4 |
what input are you selecting ?
Have you changed the left and right cards over and does the noise follow the card? I would suspect resistors as they were not of the best quality Trev |
27th Mar 2017, 4:07 pm | #5 |
Hya, problems onboth boards, one was only on phono input, the other on all, it's now up and running, on tape using a cd at the moment, will give a few hours of records shortly. So far so good.
Thanks for comments |
27th Mar 2017, 4:29 pm | #6 |
Could you update us on what you've actually done to it? It's not clear from the thread.
28th Mar 2017, 11:10 am | #7 |
I will once I have sorted the posible earth problem. It blew the trip in the workshop after a few hours. Once I know it's working I will update.
28th Mar 2017, 12:11 pm | #8 |
Still noisy one channel, phono only
28th Mar 2017, 6:09 pm | #9 |
The 521 amplifier has self shorting contacts on the phono input this has the effect of reducing the noise level. I have had these contacts fail. Put a shorted phono plug into each phono input and let us know the result.
Trev |
28th Mar 2017, 6:46 pm | #10 |
Leaky C201, C211 or C210?
29th Mar 2017, 8:19 am | #11 |
29th Mar 2017, 10:25 am | #12 |
Hya all,
update, Nick the green supressor was the culprit of the earth trip going, now sorted. Craig caps changed out of desperation. Trevor, turned amp on this morning, thunder as usual on phono. Have some phono shorting plugs, put them in, noise gone and not returned even with them removed. I would assume they have cleaned the switches just enough. I will leave it on phono all day, if all is well, clean the contacts. Many thanks all. |
29th Mar 2017, 6:20 pm | #13 |
great news the mains suppressor is also a well known fault but i still like this amplifier if you do a search on the website you will find it well documented
Trev |
29th Mar 2017, 11:15 pm | #14 |
One post moved to a new thread: https://www.vintage-radio.net/forum/...d.php?t=135286
