24th Mar 2017, 1:51 pm | #1 |
Problem with my Sony U-Matic V0-5630 player
Hi everyone. I'm hoping this is a straightforward thing to resolve.
My Sony U-Matic V0-5630 player was absolutely fine yesterday, but today when I switched it on, it wanted to fast forward for a few moments (the FW button lit up). There wasn't a tape inserted at the time. When I try to insert a tape it is unresponsive. I've opened it up to see if there is anything obvious. I've pushed the pulley wheel back to trigger an eject (was wondering if it 'thought' there was a tape inside. I haven't a clue with this. I'm hoping someone here might! |
24th Mar 2017, 6:46 pm | #2 |
Re: Problem with my Sony U-Matic V0-5630 player
I'm assuming this has a carriage bulb? If so it's probably gone. You can use a 12v small capless car dash bulb if you can't source a match.
27th Mar 2017, 4:05 pm | #3 |
Thanks for that Vauxfan2k - I'll look into that.
30th Mar 2017, 6:21 pm | #4 |
It could be the square belt under the deck that is broken. You'll need to tale off the bottom panel to check. The carriage lamps are just that, they are not involved with the tape or movement detection.
Dave. |
31st Mar 2017, 9:55 am | #5 |
Hi I have a complete machine including tapes if you need any parts let me know
Mal |
