Old 13th Feb 2017, 11:58 pm   #1
60 oldjohn
Default What is this?
I seems to be some sort of heater, but for what? The Cloth seems to clamp something to the aluminium heater.
John.
Name:	Bed warmer 004.jpg
ID:	137613   Click image for larger version
Name:	Bed warmer 005.jpg
ID:	137614   Click image for larger version
Name:	Bed warmer 006.jpg
60 oldjohn is offline
Old 14th Feb 2017, 12:02 am   #2
Goldie99
Default Re: What this?
Photo print dryer ?
Goldie99 is online now
Old 14th Feb 2017, 12:30 am   #3
electrogram
Default Re: What is this?
It's got a nice plug on it what ever it is
electrogram is offline
Old 14th Feb 2017, 12:47 am   #4
Tom_I
Tom_I's Avatar
It's a photographic print glazer. Back in the day when we developed films and prints with wet chemistry, so-called "glossy" photographic paper wasn't, if you just allowed it to air dry. So you squeegeed the print on to the polished stainless steel surface of the glazer, clamped it into position with the fabric cover, and applied some heat. If everything went well, you ended up with a nice high-gloss print.
Tom_I is offline
Old 14th Feb 2017, 10:29 am   #5
60 oldjohn
Thank you Goldie & Tom, I knew some one would know. I thought a dryer for socks, hankies, stockings or maps.
John.
Old 14th Feb 2017, 10:58 am   #6
Brigham
A CLIX plug, at a guess.
Brigham is offline
Old 14th Feb 2017, 1:23 pm   #7
emeritus
I have a similar single-sided, somewhat larger, version that you use with a separate chromium plated steel sheet that I found I could run through the power mangle of my mother's washing machine to expel air bubbles far more effectively than doing it by hand. I recently used it (minus the chrome sheet) to dry some end papers that I had made for my bookbinding evening class.
emeritus is offline
Old 14th Feb 2017, 2:24 pm   #8
60 oldjohn
I am a bit disappointed that it is photographic related, I am trying to put together a collection of early electrical Household articles. for a display I am planning.
Brigham, Yes it is indeed a "CLIX" plug, well spotted, for those not in the know, the fuse can be changed in seconds with the help of a small coin. I can start a new thread if anyone is interested.
John.
Old 14th Feb 2017, 2:34 pm   #9
Brigham
There used to be a thread for 13A plugs...
Brigham is offline
Old 14th Feb 2017, 2:54 pm   #10
60 oldjohn
I just "Search this Website" 13a plugs. #27 Ukcol has beaten me to it. The thread is now closed but has over 200 posts.
John.
Old 14th Feb 2017, 5:42 pm   #11
dseymo1
...And if it didn't you ended up with a print firmly stuck to the plate!
dseymo1 is offline
Old 14th Feb 2017, 6:21 pm   #12
It was an early household article for the photographically bent, albeit on the well off side. In fact a lot of people did contact prints on the kitchen table with not much more than a dim bulb, a bright bulb and three dishes of chemicals. Having negatives 3 1/2" x 2 1/2" helped.
Old 18th Feb 2017, 10:36 am   #13
red16v
I was rather hoping it was going to be an early Breville toaster!!
red16v is offline
Old 18th Feb 2017, 2:25 pm   #14
60 oldjohn
Me as well, a must have of the 20s, rather than a hobby device.
John.
