6th Feb 2017, 1:18 pm | #21 |
Re: Old sewing machine motor.
thank you will connect it all up and upload some photos before I try it
6th Feb 2017, 1:19 pm | #22 |
It may not be quite straightforward....
Does your machine have an earth connection (three wire mains lead) or not (two wire mains lead)? If not, the three wire suppressor can't be connected up simply since one of its leads goes to earth normally. How exactly was the old suppressor connected? 4 wires rather suggests two in from the supply and two out to the motor but some other variation may be possible.
6th Feb 2017, 1:32 pm | #23 | ||
hello yes that is correct there is 2 wires from the mains that connect to the suppressor and2 from the suppressor to the inside of the motor there is a black wire that comes from inside the motor and bolts to the body of the motor and suppressor but the mail electric cable is 2 wires not 3
6th Feb 2017, 1:42 pm | #24 |
Would any of these be any good.
http://www.ebay.co.uk/itm/HA25L-250V...cAAMXQeW5Taygh http://www.ebay.co.uk/itm/AC2A6-2-AC...mYl5JVNNQE0m3w |
6th Feb 2017, 2:43 pm | #25 |
The first one requires an earth connection. The second one doesn't.
Can you change the existing two core wiring for three core? It would be safer. You also need to consider whether any new suppressor will physically fit.
6th Feb 2017, 4:14 pm | #26 |
The sparking may be nothing to do with the lack of a capacitor. All motors of this type spark to some extent. The brushes may be worn, and/or the commutator may be worn or dirty. This is quite likely if the motor has seen plenty of use and never been serviced.
See here for general guidance, though your motor won't be exactly the same. |
6th Feb 2017, 4:47 pm | #27 |
thanks ive checked the wire its a 3 core but only from the mail plug to the foot peddle to change it all to a 3 core I would need to change the connector on back of the machine also the connector from the foot peddle
6th Feb 2017, 10:47 pm | #28 |
I'm a bit lost, now. Is the capacitor mounted in the machine at the motor or in the foot pedal?
If it's in the pedal, and there's an earth into there, the three terminal capacitor can be used, but if it's in the unearthed machine at the motor it gets "interesting". The old capacitor markings suggest it's a delta type suppressor- line to neutral, line to earth and neutral to earth but the 4-wire connection as described would only make sense for a single capacitor line to neutral.
7th Feb 2017, 11:07 am | #29 |
As I understand it:
* The suppressor is mounted on the motor with its metal case in connection with the motor frame * It is a 5-terminal feedthrough type with L & N in, L & N out and its 'earth' connection via its metal case * The supply cable is 2-core so there is no mains earth at the motor This is quite a normal setup. Many universal motors in class II appliances are suppressed with a delta-cap, either 3- or 5- lead, such that the 'earth' terminal of the cap connects to the frame only and is not accessible from the outside world. The Y-caps L>frame and N>frame bypass common-mode interference that would occur due to winding-frame capacitance without need of a connection to mains earth. It can be replaced with a 3-terminal version, where the L & N do not pass through the suppressor but are simply teed into the motor connections. The 3rd lead would connect to the motor frame as the case does now. The replacement should ideally have similar capacitance values to the failed device. Large filters with high-value Y-caps should not be used as this can raise the possible touch leakage, especially if the machine is not built to official class II standards. Does it have the square-within-a-square symbol on the plate? E2A: I have seen a couple of pics of the motor of a Pfaff 260, where it is enclosed in a plastic housing and has a double-insulated symbol. In this case I would not advise changing the cable to 3-core. The replacement suppressor must be fitted inside the plastic housing. Last edited by Lucien Nunes; 7th Feb 2017 at 11:17 am. |
7th Feb 2017, 11:52 am | #30 |
The cap values in the Maplin device aren't far off.
0.1uF replaces 0.07uF. 4700pF replaces 5000pF.
7th Feb 2017, 1:35 pm | #31 | |
Got it now!
7th Feb 2017, 9:27 pm | #32 | |
On which plate should I see if there is a square in a square symbol? Also the suppressor is fitted inside a plastic housing on the back of the pfaff 260 motor. |
8th Feb 2017, 1:12 am | #33 |
The pfaff motor is double insulated. (pic off google!). The hoover junior uses a similar setup. They also go bang.
Kevin |
8th Feb 2017, 8:03 pm | #34 |
thanks ive just checked mine and the metal plate is missing only 1 plate that says original pfaff on it
today I bought the suppressor from maplin and some new brushes hopefully I will open it up on weekend clean it up and hope for the best |
8th Feb 2017, 10:42 pm | #35 |
Still a fair amount of Pfaffing about to do, then........
12th Feb 2017, 10:41 am | #36 |
Thank you all for the help all cleaned up new brishes and a maplin suppressor all seems to work ok
12th Feb 2017, 12:48 pm | #37 |
Thanks for feedback.
