31st Jan 2017, 6:19 pm | #21 | |
Re: Looking for a vintage intercom set
31st Jan 2017, 6:27 pm | #22 |
31st Jan 2017, 7:03 pm | #23 | |
A pair of 700-series telephones, wired for a normal 2 wire line. Connect them in parallel. Now power them by connected a current-limited PSU of about 30V across the parallel-connected telephones. The PSU must be able to stand a short-circuit and have a fairly high impedance. I think we used a 24V PSU and a couple of car bulbs in series as the limiter. The idea is that if you lift the handset of one telephone and dial zero, the bell of the other telephone will tinkle. Pick up that one and you will get speech transmitted between them. An inductor in series with the PSU helps, both to add some more impedence at audio frequencies and to give a higher voltage when the dial contacts break to tinkle the bell. But too high an inductance and the dial impulse contacts suffer. |
1st Feb 2017, 11:46 am | #24 |
1st Feb 2017, 12:10 pm | #25 |
1st Feb 2017, 12:56 pm | #26 |
The other thing that occured to me is that if you look at amateur electrical books of about 100 years ago there were several designs for build-your-own intercom telephones.
I am not suggesting you have to make the carbon microphone, earpiece, induction coil, DC bell/buzzer etc. Rather that you could take parts from damaged 700 series telephones and build something similar. |
1st Feb 2017, 1:23 pm | #27 |
Another option is the stanophone circuit.
Used a two-coil DC buzzer/relay to generate a nasty buzzing sound in the earpiece. http://picclick.co.uk/ITT-STANOPHONE...l#&gid=1&pid=4 |
1st Feb 2017, 1:39 pm | #28 | |
The GPO used baretters in transmission circuits for limiting line current. Thermistors were used to prevent bell tinkle - i.e. 'Thermistor 1AN' in the Tele 314 http://www.samhallas.co.uk/repositor.../0000/N414.pdf or the little tag ended 'Thermistor 1A-1' which was added to convert a Tele 706 for shared service auto working as per diagram N806 Figure 2 http://www.samhallas.co.uk/repositor.../0000/N806.pdf Ian |
1st Feb 2017, 1:39 pm | #29 | |
And don't mix either up with a biretta or you might get into all sorts of trouble
2nd Feb 2017, 8:12 am | #30 |
Hi, I believe there was a Wireless World "home telephone exchange" design in that magazine in the 70's.
This could take up to 2 incoming lines and supply upto 10 extensions with calling between extensions as well. Ed |
2nd Feb 2017, 8:37 am | #31 |
For less than the cost of the parts for that, you could pick up a Digium TDM410P clone which, with the free Asterisk software, will turn a scrap PC into a full-blown telephone exchange. Cards are available from The Usual Places and can be configured with any combination of up to four FXS or FXO modules.. You need an FXS interface to connect to a phone, or FXO to connect to an exchange line. Probably best to get 3*FXS and 1*FXO. Supports pulse dialling, so ideal for use with vintage phones. Can also be configured to dial a number as soon as a handset is lifted, for use with dial-less phones.
2nd Feb 2017, 11:32 am | #32 | ||
2nd Feb 2017, 11:56 am | #33 |
2nd Feb 2017, 12:44 pm | #34 |
It's mentioned here, but the article is for another system: http://www.aholme.co.uk/Exchange/Design.htm
Edit - Here is a PDF of the original: http://www.classicrotaryphones.com/f...p?topic=6218.0 Last edited by Voxophone; 2nd Feb 2017 at 12:54 pm. |
2nd Feb 2017, 7:23 pm | #35 |
2nd Feb 2017, 7:28 pm | #36 |
2nd Feb 2017, 11:33 pm | #37 |
3rd Feb 2017, 2:22 pm | #38 | |
I had forgotten about it until this thread started up. Too late for feedback now on "my Ebay" No disrespect meant Ian. |
3rd Feb 2017, 2:26 pm | #39 |
Please let's not have any further discussion about the merits or otherwise of eBay sellers.
3rd Feb 2017, 3:51 pm | #40 |
Maybe more effort that you'd like, but I made some intercom telephones at school in the early 70s which I still have and use!
They are from a design published in The Boy Electrician. There are two designs, one using transformers for better audio, but I made the simple version, the circuit is shown on page 191 of the edition of the download below. (There are various republications/reprints.) You can simplify the design by using ordinary battery bells and telephone handsets, mic and earpiece modified to be wired in series - just check the current pulls the diaphragm in not out. Then at each unit and a 4.5 or 6 volt battery. I made the cases in woodwork and used some stiff sheet cut to hold the handset and operate the hook switch. There's an official free download of the book here: http://rawfire.torche.com/~opcom/tbe...lectrician.pdf Mine work over about 100 yards easily. Certainly vintage if you make them exactly to the 1930s original design! |
