17th Mar 2017, 12:54 am | #181 |
Re: All about CB radio
Re' the Jackson; I've just been Googling around to find info' & user reviews, and a few claims are being made that in stock form there's issues with RX on SSB with strong signals pumping, but there's a modification to improve this. Alternatively, people are just turning down the RF gain to improve the situation.
Not sure if I told you, Jeremy, but I also have the 80Ch Stalker 9 here and out of everything I've got it definitely takes pride of place. It's another really solid radio & it's a bit different in my opinion - I like that. I'm not too keen on the Cobra 148 these days looks wise, although I once had a Superstar 3900, but I'm led to believe they're a good solid reliable performer. I sometimes come across them listed on eBay & they fetch ridiculous money, particularly if they're boxed. I can see me becoming a bit of a collector of these old rigs, but I really shouldn't because previous experience tells me it's easy to get carried away and become a hoarder. I once had an habit of buying ex PMR gear off eBay even though I didn't really need it, and then I'd simply test it and plonk it in a storage box. Last edited by Damo666; 17th Mar 2017 at 1:06 am. |
17th Mar 2017, 1:36 am | #182 | ||
You're right about the 'characters' that are on in this area. Some of them are certainly 'larger than life' and many of them are certainly 'vintage' and as you say, stuck way back in 1983, but maybe not always in a good way, I could certainly tell you a few stories, however, most of them are ok. People say that in some areas CB radio is dead, well it's not dead around here. Most only use one channel, ie, 19, but if you know where to listen there are a couple of channels where all will be quiet until a little voice pipes up asking if anyone is there and the next thing you know there's a whole group on there having a chat. The folk that monitor these channels at different times of the evening, virtually never, ever use the 19. |
17th Mar 2017, 2:09 am | #183 | |
I think the Major 588 was the poor mans multimode 11, but I agree with what's been said with regards to the all black purposeful look. I bought mine under the counter from J Birkett in Lincoln, where I also bought that little Cybernet 1000 that i showed earlier on in this thread. I don't think that John Birkett himself actually had anything to do with the selling of these radios and it was down to a member of his staff who was working in the shop at the time, but you had to be 'in the know' to find out about them as there was a bit of a thing about the 'old school' hams getting upset if it was thought that he had anything to do with CB radio I ruined my Major 588 by modding it to within an inch of its life. It lacked a KC shift (frequency shift tune control) with it just having a single clarifier (RX only tune control). I drilled a hole in the front panel and fitted a rotary KC shift. The set as standard only had two bands, but I fitted another two, plus the 'splits', plus low power, high power, super low power and a multi tone bleep. People that saw it called it 'the porcupine', due to all the switches that were on the back. I sold it long ago to a lad who thought it was wonderful with all those mods, as this sort of thing was a bit of a rarity back in those early days. I hope it doesn't still exist anywhere and has been srapped long ago as it would be a real embarrassment for it to turn up now and for me to have to admit to all that awful work |
17th Mar 2017, 6:52 pm | #184 |
A couple of the radios which ended up in my collection came through my hands as repairs originally - I know that because I used to put a little 'signature' on the PCB of every one that I looked at and two of them eventually ended up being in my ownership.
In one case I was able to trace the whole story of where the radio had been in its convoluted journey away from me and then back to me, but as to the other, I have no idea of its history during the intervening years. I only realised it was one I had seen before when I looked inside it. So never say never... that M588 may come knocking on your door any day now. |
18th Mar 2017, 10:53 pm | #185 | |
20th Mar 2017, 10:56 pm | #186 |
I'm noticing that one of the major difficulties facing anyone just starting to get into CB repairs is the lack of a suitable RF signal generator. Synthesised AM/FM signal generators aren't cheap, even when they are quite old and second hand.
The old standby back in the day was to use another radio set to low power and running into a dummy load but in truth, the output level from that setup was always far too strong for the intended purpose. If you took a very battered but working mobile radio and completely disabled the transmitter leaving only the initial output from the VCO, that would give a much weaker signal. It might even be possible to build a switchable attenuator inside a diecast box and put it inside the 'host' unit and take the output from that to the SO239 socket on the rear of the unit. The main problem would be stopping stray radiation coming out of the unit, along the power leads for example. On an 'ideal' test signal generator the only place the signal should be coming out of is the output socket, and nowhere else. If you picked something with a sine-wave roger bleep (ie, Amstrad chassis) you could arrange for the beep tone to be either continuously on or continuously off, giving the option to modulate the output signal with a sinewave test tone. It wouldn't begin to approach the low RF leakage and fully variable level output from a 'proper' purpose made generator, but it might be better than trying to tune up on a local transmitter or on off-air signals. |
