23rd Mar 2017, 9:53 pm | #21 | |
Re: WWII oscilloscope bandwidth mystery?
Harmonic content is better examined on a spectrum analyser in the frequency domain. These weren't available during WWII either, but who cared. No-one else was working even at 3GHz, so there was no need to worry about interfering with someone else at 6, 9 or 12GHz! The first time I needed a scope at VHF (around 100MHz) was when I started design of frequency synthesisers at Pye Telecom in the late 1970s. I had to design the frequency dividers nearly from scratch because back then there were very ICs on the market to do the job. I had to design a transistor stage for instance to interface between ECL and CMOS - and that did require a scope. I used a sampling scope, which showed up voltage levels and rise and fall times. As I recall it had a bandwidth out to about 2GHz with the right probes. Richard |
