10th Nov 2022, 1:59 pm | #81 |
Re: Ceramic and Crystal cartridge specs.
Are stereo LP tips different from mono (microgroove, not 78 rpm) tips then?
The plot thickens ...
Now where on earth did I remove that from? |
10th Nov 2022, 4:11 pm | #82 |
The rubber shank mounting for the TC8S was not the same as the one in the mono TC8 cartridges. It was definitely a softer, dare I say, more compliant mounting, which I suspect did provide some degree of vertical compliance.
Also, I seem to recall Ronette stylii having similar properties across the mono/ stereo range, only the mounting shanks differing as per the TC8 range. Also, In reply to the previous post, originally, a mono stylus had a radius of 1 mil, which was used until the 0.7 mil radius was introduced in order to play stereo records. Last edited by david freeman; 10th Nov 2022 at 4:17 pm. |
11th Nov 2022, 10:09 am | #83 |
There's no plot at all. Stereo styli have been in established use for 64 years. Yet in spite of this there is still confusion about them. And not only do they have a different tip diameter, but also some have different profiles.
Edward. |
13th Nov 2022, 5:16 pm | #84 |
It's interesting to note that manufacturers progressively worked at making mono cartridges stereo compatible, and presumably also made mono (0.001" tip radius) and stereo (0.0007" tip radous) styli. What seems amazing to me is that the 45 deg cut for stereo records didn't fully take into account the backward compatibility issue by making them playable using the original 0.001" tip radius stylus.
This is an interesting website:-http://pspatialaudio.com/stylus_grooves.htm#:~:text=A%20original%2C%20stand ard%20microgroove%20diamond,as%20illustrated%20at% 20(a). No wonder the purchasers of cartridges and styli (and to some extent the sellers too!) were somewhat bamboozled! I mean it's not as if the cartridge has SC written on the side of it or a stylus has 0.001" tip radius written on it. These days I'm not even sure we can rely upon the ST number of the styli to deduce whether its a 0.001" or 0.0007" tip radius! Mmmmm... as I say a minefield.
Now where on earth did I remove that from? Last edited by af024; 13th Nov 2022 at 5:22 pm. |
13th Nov 2022, 5:24 pm | #85 |
Maybe all ST styli were 0.0007" tip radius?
29th Jan 2023, 6:28 pm | #86 |
Attached image of BSR TC10, 12, 14 Cartridges found on the web
8th May 2023, 10:47 pm | #87 |
One thing I would like to see here (if possible) is data on the Sonotone 25x9 and 35x9 cartridges - and what the Garrard equivalents are, e.g. KS41A?
14th Nov 2023, 5:19 pm | #88 |
Cartridge Data
While searching online for something else I stumbled on a document about Astatic cartridges which has cross reference data and also technical data so I thought I would share here for interest.
20th Nov 2023, 9:03 am | #89 |
hi Peter, is it my PDF reader at fault? but I can only see 5 pages of the alleged 35+. the missing pages are temptingly interesting
Regards Joe "Hayer Joe, where ya going with that deck in your hand?" - Jimi Hendrix Experience |
20th Nov 2023, 12:53 pm | #90 |
24th Nov 2023, 9:11 am | #91 |
I have only included those pages for the technical specs if you who want the full document this is the link https://www.canadianastatic.com/uplo..._reference.pdf
5th Dec 2023, 9:58 am | #92 |
4th Jan 2024, 6:44 pm | #93 | |
I seem to remember the 25** models were crystal higher output types with 'plastic' cantilevers holding the diamond/sapphire stylus chips. I still have a 3559 and a single tip stylus marketed by Musonic. It's very good indeed at around 4g tracking I remember it being as good subjectively as the classic Sonotone 9TA-HC. BSR's late slimline models and the Acos 104 when new was also comparable I'd suggest. I missed out on a pair of Decca Derams, one with 'best' stylus fitted and have always been intrigued how good these were - apologies for the digression.
Best wishes, Dave |
4th Jan 2024, 7:49 pm | #94 |
Attached for reference some Sonotone pictures. No idea where I got them, internet probably (perhaps even here!)
- The 2509, 2529 and 2539 (all pictured) are the low compliance higher output types, using the plastic shanked styli (GDD1, etc). - The 3509 is a medium output (AKA Garrard KS41). I think (don't have one nearby at present) that the 3549 (quoted 100mv o/p) and the 3559 (quoted 70mV o/p) are the same carts but sold with higher compliance stylus (see note below) which dictated the output. That's my theory - I would welcome info that would prove/disprove it! - The 35xx carts use the Styli commonly marked with Garrard prefix A, B or C. the A type is more robust. The 'C' type has a longer, finer shank and tracks the lightest, also giving lower output. Pics to follow.
Regards, Ben. |
4th Jan 2024, 8:18 pm | #95 |
Attached pictures for comparison of B and C type styli for the Sonotone 35xx series. You can see the difference in the length of the cantilever if you look closely.
Regards, Ben. |
