24th Feb 2004, 1:07 pm | #1 |
Success with Waterslide transfers.
I have folowed the advice in the forum and successfully used transparent ink jet waterslide paper to make a transfer for the back of a 1938 Rola speaker. First, I scanned the old transfer on the speaker. Then I cleaned up the image (it took ages because it was pretty well shot) using photo editing software. The background to the original logo was gold, which I cannot print with an ink jet. I therefore removed the gold from the image, by filling the area with white. I then had an image with only the black and red lettering present, from which I made a new transfer. I masked the back of the speaker, having already resprayed the frame black, and sprayed the area for the transfer with gold. Finally, I put the transfer onto the gold area and it looks super. I will do the same with a 'Bush' cabinet logo which similarly had a gold background. Thanks to all for the info on waterslide paper. It is wonderful.
One hint - The instructions advise painting the area for the transfer with dilute PVA adhesive. I have found that it is necessary to add a trace of washing up liquid to the PVA to get it to wet the surface properly. I did this with a plastic model of Concorde, which has zillions of weeny transfers and they seem to have stuck very well. Nigel |
24th Feb 2004, 1:26 pm | #2 |
Re: Success with Waterslide transfers.
Can you point me in the direction of the original info on waterslide transfers please?
Thanks, Ed Dinning |
25th Feb 2004, 10:40 pm | #3 |
I am aware of at least two tracks on this general subject, both lodged under Radio Restoration Help, under the threads headed Maker Logo Transfer and Bush Logo. I think there may also be others buried away somewhere, but not sure where.
You might also find the following link of interest, covering the way I cracked my own particular problem: http://web.onetel.net.uk/~rahutchinson/hmvlogos.htm Regards Rod |
26th Feb 2004, 1:26 pm | #4 |
Thanks Rod, very useful.
Ed |
26th Feb 2004, 7:07 pm | #5 |
Hi Nigel,
Well done, I will attempt your method when I get a chance and the paper. I am currently refinishing a Bush AC 71, I presume your Bush has a similar logo,after a few attempts and jiggling with lights and flash I managed to get a reasonable close up photo,if it will help I'll send it, just ask. Cheers, Tony. |
27th Feb 2004, 10:42 am | #6 |
Dear Tony,
Thanks, but I scanned what was left of the original Bush Logo on my SW45 and have used the computer to make a version where what was gold is now transparent. The rest is red and black, both of which showed up very well against the gold background on the speaker. I just have to get the final finish on the cabinet and then I will give it a go. Cheers Nigel |
