24th Feb 2017, 12:20 am | #1 |
Tandberg TP41. Capacitor value?
Can anyone tell me the value of C514 as cannot for the life of me make out the schematic print? The one in it isn't original.
24th Feb 2017, 10:30 am | #2 |
Re: Tandberg TP41. Capacitor value?
24th Feb 2017, 10:31 am | #3 |
500uF in the schematic I'm looking at.
Lawrence. |
24th Feb 2017, 11:01 am | #4 |
500uf right , just the one that's in is 400uf 16v not original
24th Feb 2017, 11:03 am | #5 |
Have you got a tp41 Laurence?
24th Feb 2017, 11:56 am | #6 |
No I haven't, only a copy of the schematic.
Lawrence. |
24th Feb 2017, 11:58 am | #7 |
Ok just wondering about this dial light. It comes on when pressing the volume down just not sure if it's meant to stay on when release or only stay on when you have it pressed in. If that makes sense
24th Feb 2017, 2:30 pm | #8 |
On a battery-powered radio, in the days of tungsten filament bulbs, an intermittent dial light was an essential power-saving measure. Some sets were designed to be continuously illuminated when running on mains power.
24th Feb 2017, 5:51 pm | #9 |
So is it meant to stay on when pressed down or just on when finger kept pressed on button?
25th Feb 2017, 10:16 am | #10 |
Work the same as a doorbell. Only on whilst being pushed. Use one hand for light, t'other to tune the set.
25th Feb 2017, 4:49 pm | #11 |
Ok herald just seemed a bit odd as a lot of these were marketed as car radio , so while pressing the light with one had , tuning with the other, whos driving the car lol
25th Feb 2017, 5:21 pm | #12 |
25th Feb 2017, 6:34 pm | #13 |
The "car adaptor" on the schematic shows the lamps always powered (via a 47 ohm resistor) when the radio is on and powered from the car's battery. When using the radio as a portable the lamps are powered via a separate switch. I think we can conclude that this switch must be a press and hold type (non-latching) and the radio is working as it was designed.
25th Feb 2017, 7:16 pm | #14 |
interestingly i have TP43 and i don't have a light function which is also one that could be mounted in a special bracket for a car. these radios are excellent and have a very good reception and sound. here is schematic for the TP41 might be more readable?
Clive |
25th Feb 2017, 11:10 pm | #15 |
Thanks for a clearer schematic rover much appreciated and thanks to others for input on light issue
25th Feb 2017, 11:35 pm | #16 |
well i couldn't pass up another Tandberg owner few and far between
26th Feb 2017, 12:02 am | #17 |
Probaby due to the availbility of tandberg sets being few and far between, truth be known i have a soft spot for tandberg radios but im a hacker guy deep down.
19th Mar 2017, 8:29 pm | #18 |
Lol now got 2 rover.
