21st Feb 2017, 10:30 pm | #1 |
Sky Casket output transformer resistance
Last year, while back home in the UK for a holiday, I treated myself to an Ever Ready Sky Casket. I have just put it on the bench, and have found that all four valves are dud. Three have open filaments, and the fourth has very low emissions. Anyway, before looking for a set of valves I thought it would be a good idea to verify that the output transformer is OK. I disconnected one lead from primary and secondary, and checked DC resistances. Primary is around 550 ohms, and secondary is 0.7. Could anyone tell me if these are reasonable values?
Thanks in advance for the help. Regards, Colin |
21st Feb 2017, 10:34 pm | #2 |
Re: Sky Casket output transformer resistance
They sound ok to me.
21st Feb 2017, 10:34 pm | #3 |
The DC resistance of the output transformer sounds correct.
Cheers Mike T Crossed with Hamish
21st Feb 2017, 10:40 pm | #4 |
Sounds reasonable. Another check would be to reconnect speaker to secondary, connect a 1k resistor across the primary then dab a 9V battery across the primary. This should give some good crackling noises from the speaker.
The 1k will limit inductive kick back voltages to a safe level for the TX insulation.
22nd Feb 2017, 12:39 am | #5 |
Thanks you all for the prompt replies. I now feel confident about searching for a set of valves.
Regards, Colin |
